We registered for the MFI, and purchased BC127-DEVKIT001-MFI in Avnet. Trying to enable iAP.
When we send commands which relate iAP configurations like:
get IAP_PARAMS
set ENABLE_IAP=ON
get ENABLE_IAP
always it returns the “Configuration not found” error:
ERROR 0x001A
Why does it happen? How can we use those configurations?
Here are responses for version command:
version
BlueCreation Copyright 2016
Melody Audio V6.0.48 MFI
Build: 1472830521
Bluetooth address 20FABB025933
Profiles: A2DP AVRCP HFP BLE SPP PBAP MAP IAP
Codecs: SBC
It says the dev kit is for MFi.
But, for config command, the response is like this:
AUDIO=0 0
AUDIO_ANALOG=15 15 1 OFF
AUDIO_DIGITAL=0 44100 64 100A00
AUTOCONN=0
BALANCE=100 100
BATT_CONFIG=OFF 145 4250 1500 150
BLE_CONFIG=0 OFF 40 ON
BLE_CONN_PARAMS=128 12 6 40 0 400 50 400 400 61 400 400
BT_VOL_CONFIG=A A 10
CLASS_1=OFF
CMD_TO=20
COD=240404
CODEC=0 OFF
CONN_TO=0
DEEP_SLEEP=OFF
DISCOVERABLE=2 0
ENABLE_BATT_IND=ON
ENABLE_CAPSENSE=OFF
ENABLE_LED=ON
GPIO_CONFIG=ON 0 255
HFP_CONFIG=OFF ON OFF OFF OFF
HIGH_SPEED=OFF OFF
LOCAL_ADDR=20FABB025933
MAX_REC=2
MUSIC_META_DATA=OFF
MUSIC_OLD_AVRCP=OFF
NAME=BC-025933
NAME_SHORT=BC25933
PIN=0000
PROFILES=2 0 2 0 2 1 2 1 0 0 1 1
REMOTE_ADDR=000000000000
SSP_CAPS=3
TWS_CONFIG=OFF 1 2
UART_CONFIG=9600 OFF 0
USB_HOST=OFF
VREG_ROLE=1
It doesn’t include iAP related configurations.
We checked jumper settings for co-processor according to “Configuring IAP” doc. Here is the picture of our board:
It should correct.
So, what can be the problem?
