Im trying to understand if i can send command and receive response over SPP. I entered data mode on BC127. Now open Android app and trying to send command like INQUIRY 2 for example. I can see on terminal that INQUIRY 2 received but actual INQUIRY not starting.
I would like to clarify my question.I know i can control module from BC Smart and send command. But how do we get full result what is shown on terminal? I get only OK, pending etc… How to get respond from INQUIRY, NAME, LIST commands to smartphone?
Here is my update configuration.
FLOW CTRL is on
I tried different baud rate but no luck
AUDIO=0 0
AUDIO_ANALOG=15 15 1 OFF
AUDIO_DIGITAL=0 44100 64 100A00 OFF
AUTOCONN=0
AUTO_DATA=OFF ON ON
BALANCE=100 100
BATT_CONFIG=OFF 145 4250 1500 150
BLE_CONFIG=0 ON 40 ON
BLE_CONN_PARAMS=128 12 6 40 0 400 50 400 400 61 400 400
BT_VOL_CONFIG=A A 10 1
CLASS_1=OFF
CMD_TO=20
COD=240404
CODEC=0 OFF
CONN_TO=0
DEEP_SLEEP=OFF
DISCOVERABLE=1 0
ENABLE_BATT_IND=ON
ENABLE_CAPSENSE=OFF
ENABLE_LED=ON
GPIO_CONFIG=ON 0 255
HFP_CONFIG=OFF ON OFF OFF OFF
HIGH_SPEED=OFF OFF
LOCAL_ADDR=20FABB019121
MAX_REC=2
MUSIC_META_DATA=OFF
MUSIC_OLD_AVRCP=OFF
NAME=BC-019121
NAME_SHORT=BC19121
PIN=0000
I have 2 devices connected 1 with Android Smart to send command and another with terminal connected over SPP. I confirmed module in the Data mode. I can issue commands with Android Smart and get response OK, but no data appears in the terminal. I would expect all data response should flow to SPP as described in bluecreation.com/MelodyAudi … ata%20mode
