BC127 call echo - help
I am fighting a call echo issue using the BC127. Audio from the speaker is getting back into the mic and the phone calling the bc127 will hear an echo of their own voice.
I have loaded the CVC demo, but it does not seem to make any difference at all. Can anyone tell me what I might have wrong here?
LOCAL_ADDR=20FABB000183
APTX=3465 57F8 42AE A223 4820
CVC=3465 57F8 42AE FC81 0000
AUDIO=0 0
AUDIO_ANALOG=16 15 0 OFF
AUDIO_DIGITAL=0 44100 64 100A00 OFF
AUTOCONN=1
AUTO_DATA=OFF OFF OFF
BALANCE=100 100
BATT_CONFIG=ON 145 4250 1500 30
BLE_CONFIG=0 OFF 40 ON
BLE_CONN_PARAMS=128 12 6 40 0 400 50 400 400 61 400 400
BT_VOL_CONFIG=A A 10 1
CLASS_1=OFF
CMD_TO=20
COD=240404
CODEC=0 OFF
CONN_TO=0
DEEP_SLEEP=OFF
0002 0003 0004 0005 0006 0007 0008
DISCOVERABLE=2 0
ENABLE_BATT_IND=ON
ENABLE_CAPSENSE=OFF
ENABLE_LED=ON
GPIO_CONFIG=ON 0 255
HFP_CONFIG=ON ON OFF ON OFF
HIGH_SPEED=OFF OFF
MAX_REC=2
MUSIC_META_DATA=OFF
MUSIC_OLD_AVRCP=OFF
NAME=HFBTBTN-00183
NAME_SHORT=HF00183
PIN=0000
PROFILES=2 0 2 0 1 0 1 1 0 0 1 0
REMOTE_ADDR=000000000000
SSP_CAPS=3
TWS_CONFIG=OFF 1 2
UART_CONFIG=9600 OFF 0
USB_HOST=OFF
VREG_ROLE=1
Michael
have your ever found the solution for this?
I have tried many ways for the same issue, but noone could help. (Not even Sierra, they are quite unhelpful and unresponsive).
Thanks!
Dan,
You should load the cVc license then tune the gain. Use the cVc parameters to tune the gain and enable / disable the pre-amplifier:
CVC Parameters:
228Z 0000 1A00 8000 0000 XXYY 0000 0000 0000 0000 0000 0020 0000 XXYY
Where:
Z = 0 for Narrow-Band
Z = 4 for Wide-Band
Where XXYY is the Microphone configuration:
XX - Enable/disable 21 dB Pre-Amp
00 = disabled
80 = enabled
YY - Gain in dB. Possible values are:
C0: -27
C1: -23.5
C2: -21
C3: -17.5
C4: -15
C5: -11
C6: -9
C7: -5.5
C8: -3
C9: 0
CA: 3
CB: 6
CC: 9
CD: 12
CE: 15
CF: 18
D0: 21.5
D1: 24
D2: 27.5
D3: 30
D4: 33.5
D5: 36
D6: 39.5
Thanks!
-Ted
First I have to buy the license then I will have the cVc option in the config? (Right now it seems I don’t have any cVc option).
Thank you!
Yeah, but all of this should work with the demo license.
I would set theCVC license to all zeros, then try the tool again.
Okay, thanks, I will try this way too. :slight_smile:
