AT Commands of EM919x/EM7690 modules
I am doing 5G NR NSA measurements and trying to read signal parameters like bandwidth, strength of signal, etc. Can you please tell me which AT Command should I use in this case, AT!GSTATUS? or AT!NRINFO?
Yes, you can use those two commands
My measurement takes 30 seconds and I read the signal parameters every second using minicom and the command AT!NRINFO?. The problem is that it doesn’t always give me values. For example after 20 seconds of measurement all the values are — . Using AT!GSTATUS? the problem doesn’t seem to appear. Do you have any idea what the problem could be?
you need to keep on generate data traffic in order to have 5G connection.
