AT command reference for EM7565
I am trying to bring up my EM7565 device with Ubuntu 18.04 first and then eventually, I have to do the same with Raspberry Pi 3 B(Rasbian). To start with I am trying to play with the device. It is in offline mode i.e. not connected to any network. I have not yet inserted any SIM yet. So far what I can see is as below:
$ dmesg | grep -i “ttyUSB*”
[242286.496368] usb 2-1.8: GobiSerial converter now attached to ttyUSB0
[242286.496878] usb 2-1.8: GobiSerial converter now attached to ttyUSB1
[242286.497663] usb 2-1.8: GobiSerial converter now attached to ttyUSB2
Now, I am trying to issue AT commands to start talking to the device connected to my Ubuntu. So I do the below:
$ sudo minicom -s
Then
I can issue ati command and get the below:
ati
Model: EM7565
Revision: SWI9X50C_01.08.04.00 dbb5d0 jenkins 2018/08/21 21:40:11
IMEI: 353533100239139
IMEI SV: 8
FSN: UF923776240415
+GCAP: +CGSM,+DS,+ES
also, I can issue
at+gmr
Apart from these two commands nothing seems to be returning anything.
For the AT command reference, should I follow this document:
41111748 AirPrime EM75XX AT Command Reference r2.pdf
or this one:
2130309_MP7xx_AT_Command_Reference.pdf ?
I can understand some of the commands would return erroneous response but apart from the above two commands I cannot even type the commands on the minicom console.
Am I using the right firmware for the device? The above one seems to me have been released on the 2018/08/21. Is this the recommended one?
Please advise.
Thanks and regards,
Vivek
Hi @vivek.bhadra,
Please download QMI Driver at https://source.sierrawireless.com/resources/airprime/software/usb-drivers-linux-qmi-software-latest/#sthash.dhSCBFd1.qJTbIbgg.dpbs and
Download document at https://source.sierrawireless.com/resources/airprime/software/linux-qmi-sdk-application-developer-guide-1,-d-,26/#sthash.B00YnDId.dpbs and follow instruction on page 11.
After you finish installing driver, please try your test again.
Just for the records, once I inserted the SIM I could issue all the below commands and more and it’s working now:
Welcome to minicom 2.7.1
OPTIONS: I18n
Compiled on Aug 13 2017, 15:25:34.
Port /dev/ttyUSB2
Press CTRL-A Z for help on special keys
ati
Model: EM7565
IMEI SV: 8
FSN: UF923776240415
+GCAP: +CGSM
at+creg?
+CREG: 0,1
at+cgreg?
+CGREG: 0,1
at+cgdcont?
+CGDCONT: 1,“IPV4V6”,"",“0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0”,0,0,0,0
at+cgdcont=1,“IPV4V6”,“wap.vodafone.co.uk”
at!scact=1,1
