I’m using the firmware version 7.44 on a XTEND FXT009 EDGE. When I connect by serial port and try to execute command AT+CGATT=1 just waits for a few seconds and answers with error.
I’m trying to initiate the gprs stack, is there any way to do it instead of this one?
+CSQ: 16,0
+CREG: 0,1
AT + CGATT -> OK(son it seems to be working now. Why? I cannot say… humm)
AT+CPIN? -> READY
+CREG: 0,1
+CERR -> 0(No error?)
CSQ: 17,0
By the way, is it mandatory for CGATT to have the cable plugged? It isn’t the original reason for the failure, but I notice that doing it without cable plugged made CREG returns 148(unrecognized error?) and CEER returns 266…
BTW, you mentioned “cable”, what exactly it is? Are you saying the antenna or UART/USB cable?
For failure cause, 266, it does not seems to be a valid code.
If in case it is a typo of 226, then it make sense with antenna disconnected as no network signal…
226 - Unsuccessful attach cause NO SERVICE
