mkupke
November 14, 2014, 4:58pm
1
I use the (automotive) AR7554 on the AR7 EvalBoard and have inserted a 4GB MMC card. While booting there are several mmc0 output messages, here is the list from the dmesg with grep for mmc:
root@swi-mdm9x15:~# dmesg | grep mmc
mmc0: mci-version: 18
mmc0: bam physical base=0x12182000
mmc0: bam virtual base=0xd0090000
mmc0: BAM device registered. bam_handle=0xce997000
mmc0: Qualcomm MSM SDCC-BAM at 0x0000000012182000 irq 130
mmc0: Qualcomm MSM SDCC-DML at 0x0000000012180800
mmc0: No card detect facilities available
mmc0: Qualcomm MSM SDCC-core at 0x0000000012180000 irq 136,0 dma -1 dmacrcri -1
mmc0: 8 bit data mode disabled
mmc0: 4 bit data mode enabled
mmc0: polling status mode disabled
mmc0: MMC clock 400000 → 48000000 Hz, PCLK 0 Hz
mmc0: Slot eject status = 0
mmc0: Power save feature enable = 1
mmc0: SPS-BAM data transfer mode available
mmc0: host does not support reading read-only switch. assuming write-enable.
mmc0: new high speed SDHC card at address 0002
mmcblk0: mmc0:0002 00000 3.70 GiB
mmcblk0: p1
yaffs: dev is 187695105 name is “mmcblk0p1” rw
I partitioned the MMC card using
fdisk /dev/mmcblk0
and created filesystem using
mkfs.minix
on it.
root@swi-mdm9x15:~# cat /proc/partitions
major minor #blocks name
31 0 1024 mtdblock0
31 1 20736 mtdblock1
31 2 50688 mtdblock2
31 3 40704 mtdblock3
31 4 152576 mtdblock4
31 5 5376 mtdblock5
31 6 2304 mtdblock6
179 0 3880960 mmcblk0
179 1 3880797 mmcblk0p1
I’m not able to mount the partition mmcblk0p1 to any mount point:
Where is my fault?
There is no switch to enable/disable the MMC card adapter on the EvalBoard and as you see I can access it via fdisk and mkfs.minix it should be mountable.
Thanks in advance,
Martin…
root@swi-mdm9x15:~# fwupdate query
Firmware Version: SWI9X15A_06.03.17.00 r23798 CNSHZ-AR-BUILD 2014/08/08 12:53:51
Bootloader Version: SWI9X15A_06.03.17.00 r23798 CNSHZ-AR-BUILD 2014/08/08 12:53:51
Linux Version: 3.4.36-yocto-standard #1 PREEMPT Fri Aug 8 07:16:46 EDT 2014
davidc
November 14, 2014, 11:01pm
2
Hiya,
Are the minix file system drivers built into the kernel? Or are they available as modules for your kernel?
Have you tried using the vfat file system on your MMC card instead of minix?
ciao, Dave
mkupke
November 17, 2014, 4:32pm
3
as far as I know it’s only possible to format the partition created with fdisk by a mkfs (make filesystem) command and there is only mkfs.minix available. There is nothing else, no mkfs.vfat…
root@swi-mdm9x15:~# ls -la /lib/modules/3.4.36-yocto-standard/kernel/
drwxr-xr-x 1 root root 4096 Aug 8 2014 .
drwxr-xr-x 1 root root 4096 Aug 11 2014 ..
drwxr-xr-x 1 root root 4096 Aug 8 2014 net
root@swi-mdm9x15:~# ls -la /lib/modules/3.4.36-yocto-standard/kernel/net/
drwxr-xr-x 1 root root 4096 Aug 8 2014 ..
drwxr-xr-x 1 root root 4096 Aug 11 2014 802
drwxr-xr-x 1 root root 4096 Aug 11 2014 bridge
drwxr-xr-x 1 root root 4096 Aug 8 2014 ipv4
drwxr-xr-x 1 root root 4096 Aug 11 2014 llc
drwxr-xr-x 1 root root 4096 Aug 11 2014 netfilter
As far as I can see, the fs (filesystem) drivers are already builtin:
cat /lib/modules/3.4.36-yocto-standard/modules.builtin
kernel/arch/arm/mach-msm/lpass-8960.ko
kernel/arch/arm/mach-msm/rpm_stats.ko
kernel/arch/arm/mach-msm/rpm_log.ko
kernel/arch/arm/mach-msm/sierra_i2c.ko
kernel/arch/arm/mach-msm/sierra_spi.ko
kernel/kernel/configs.ko
kernel/fs/mbcache.ko
kernel/fs/btrfs/btrfs.ko
kernel/fs/ext2/ext2.ko
kernel/fs/ext3/ext3.ko
kernel/fs/ext4/ext4.ko
kernel/fs/fat/fat.ko
kernel/fs/fat/vfat.ko
kernel/fs/jbd/jbd.ko
kernel/fs/jbd2/jbd2.ko
kernel/fs/lockd/lockd.ko
kernel/fs/nfs/nfs.ko
kernel/fs/nls/nls_base.ko
kernel/fs/squashfs/squashfs.ko
kernel/fs/unionfs/unionfs.ko
kernel/fs/yaffs2/yaffs.ko
kernel/crypto/crypto.ko
kernel/crypto/crypto_wq.ko
kernel/crypto/crypto_algapi.ko
kernel/crypto/aead.ko
kernel/crypto/crypto_blkcipher.ko
kernel/crypto/chainiv.ko
kernel/crypto/eseqiv.ko
kernel/crypto/crypto_hash.ko
kernel/crypto/pcompress.ko
kernel/crypto/cryptomgr.ko
kernel/crypto/hmac.ko
kernel/crypto/md5.ko
kernel/crypto/sha1_generic.ko
kernel/crypto/cbc.ko
kernel/crypto/des_generic.ko
kernel/crypto/crc32c.ko
kernel/crypto/authenc.ko
kernel/crypto/authencesn.ko
kernel/crypto/rng.ko
kernel/crypto/krng.ko
kernel/block/blk-cgroup.ko
kernel/block/deadline-iosched.ko
kernel/block/cfq-iosched.ko
kernel/drivers/base/firmware_class.ko
kernel/drivers/base/regmap/regmap-i2c.ko
kernel/drivers/base/regmap/regmap-spi.ko
kernel/drivers/block/brd.ko
kernel/drivers/char/diag/diagchar.ko
kernel/drivers/char/hw_random/rng-core.ko
kernel/drivers/char/hw_random/atmel-rng.ko
kernel/drivers/char/hw_random/msm_rng.ko
kernel/drivers/cpufreq/cpufreq_stats.ko
kernel/drivers/cpufreq/cpufreq_performance.ko
kernel/drivers/cpufreq/cpufreq_powersave.ko
kernel/drivers/cpufreq/cpufreq_userspace.ko
kernel/drivers/cpufreq/cpufreq_ondemand.ko
kernel/drivers/cpufreq/cpufreq_conservative.ko
kernel/drivers/cpufreq/freq_table.ko
kernel/drivers/gpio/pm8xxx-gpio.ko
kernel/drivers/gpio/pm8xxx-mpp.ko
kernel/drivers/gpio/sierra_gpio_wake_n.ko
kernel/drivers/gpu/ion/ion.ko
kernel/drivers/gpu/ion/ion_heap.ko
kernel/drivers/gpu/ion/ion_system_heap.ko
kernel/drivers/gpu/ion/ion_carveout_heap.ko
kernel/drivers/gpu/ion/ion_iommu_heap.ko
kernel/drivers/gpu/ion/ion_cp_heap.ko
kernel/drivers/hid/hid.ko
kernel/drivers/hid/usbhid/usbhid.ko
kernel/drivers/hwmon/hwmon.ko
kernel/drivers/hwmon/pm8xxx-adc.ko
kernel/drivers/hwmon/pm8xxx-adc-scale.ko
kernel/drivers/i2c/i2c-core.ko
kernel/drivers/i2c/i2c-dev.ko
kernel/drivers/i2c/busses/i2c-qup.ko
kernel/drivers/input/input-core.ko
kernel/drivers/input/mousedev.ko
kernel/drivers/input/evdev.ko
kernel/drivers/input/keyboard/atkbd.ko
kernel/drivers/input/misc/pmic8xxx-pwrkey.ko
kernel/drivers/input/mouse/psmouse.ko
kernel/drivers/input/serio/serio.ko
kernel/drivers/input/serio/serport.ko
kernel/drivers/input/serio/libps2.ko
kernel/drivers/leds/led-class.ko
kernel/drivers/leds/leds-pm8xxx.ko
kernel/drivers/mfd/mfd-core.ko
kernel/drivers/mfd/wcd9xxx-core.ko
kernel/drivers/mfd/wcd9xxx-irq.ko
kernel/drivers/mfd/wcd9xxx-slimslave.ko
kernel/drivers/mfd/pm8018-core.ko
kernel/drivers/mfd/pm8xxx-debug.ko
kernel/drivers/mfd/pm8xxx-pwm.ko
kernel/drivers/mfd/pm8xxx-misc.ko
kernel/drivers/mmc/card/mmc_block.ko
kernel/drivers/mmc/core/mmc_core.ko
kernel/drivers/mmc/host/msm_sdcc.ko
kernel/drivers/mtd/mtd.ko
kernel/drivers/mtd/mtdchar.ko
kernel/drivers/mtd/mtd_blkdevs.ko
kernel/drivers/mtd/mtdblock.ko
kernel/drivers/mtd/chips/chipreg.ko
kernel/drivers/mtd/devices/msm_nand.ko
kernel/drivers/mtd/nand/nand_ids.ko
kernel/drivers/net/mii.ko
kernel/drivers/net/netconsole.ko
kernel/drivers/net/usb/kaweth.ko
kernel/drivers/net/usb/pegasus.ko
kernel/drivers/net/usb/asix.ko
kernel/drivers/net/usb/cdc_ether.ko
kernel/drivers/net/usb/dm9601.ko
kernel/drivers/net/usb/smsc75xx.ko
kernel/drivers/net/usb/smsc95xx.ko
kernel/drivers/net/usb/net1080.ko
kernel/drivers/net/usb/cdc_subset.ko
kernel/drivers/net/usb/zaurus.ko
kernel/drivers/net/usb/mcs7830.ko
kernel/drivers/net/usb/usbnet.ko
kernel/drivers/net/usb/int51x1.ko
kernel/drivers/net/usb/cdc_ncm.ko
kernel/drivers/power/power_supply.ko
kernel/drivers/regulator/pm8xxx-regulator.ko
kernel/drivers/regulator/msm-gpio-regulator.ko
kernel/drivers/rtc/rtc-pm8xxx.ko
kernel/drivers/scsi/scsi_mod.ko
kernel/drivers/scsi/scsi_tgt.ko
kernel/drivers/scsi/sd_mod.ko
kernel/drivers/scsi/sg.ko
kernel/drivers/scsi/ch.ko
kernel/drivers/slimbus/slim-msm-ctrl.ko
kernel/drivers/spi/spidev.ko
kernel/drivers/spi/spi_qsd.ko
kernel/drivers/thermal/thermal_sys.ko
kernel/drivers/thermal/msm8960_tsens.ko
kernel/drivers/thermal/pm8xxx-tm.ko
kernel/drivers/tty/serial/serial_core.ko
kernel/drivers/tty/serial/msm_serial_hs_lite.ko
kernel/drivers/tty/serial/kgdboc.ko
kernel/drivers/usb/usb-common.ko
kernel/drivers/usb/class/cdc-acm.ko
kernel/drivers/usb/core/usbcore.ko
kernel/drivers/usb/gadget/udc-core.ko
kernel/drivers/usb/gadget/ci13xxx_msm.ko
kernel/drivers/usb/host/ehci-hcd.ko
kernel/drivers/usb/otg/msm_otg.ko
kernel/drivers/usb/serial/usbserial.ko
kernel/drivers/usb/serial/option.ko
kernel/drivers/usb/serial/qcserial.ko
kernel/drivers/usb/serial/sierra.ko
kernel/drivers/usb/serial/usb_wwan.ko
kernel/drivers/usb/serial/GobiSerial.ko
kernel/drivers/usb/storage/usb-storage.ko
kernel/drivers/usb/storage/ums-alauda.ko
kernel/drivers/usb/storage/ums-cypress.ko
kernel/drivers/usb/storage/ums-datafab.ko
kernel/drivers/usb/storage/ums-freecom.ko
kernel/drivers/usb/storage/ums-isd200.ko
kernel/drivers/usb/storage/ums-jumpshot.ko
kernel/drivers/usb/storage/ums-karma.ko
kernel/drivers/usb/storage/ums-onetouch.ko
kernel/drivers/usb/storage/ums-sddr09.ko
kernel/drivers/usb/storage/ums-sddr55.ko
kernel/drivers/usb/storage/ums-usbat.ko
kernel/sound/soundcore.ko
kernel/sound/core/snd.ko
kernel/sound/core/snd-hwdep.ko
kernel/sound/core/snd-timer.ko
kernel/sound/core/snd-pcm.ko
kernel/sound/core/snd-page-alloc.ko
kernel/sound/core/snd-rawmidi.ko
kernel/sound/soc/snd-soc-core.ko
kernel/sound/soc/codecs/snd-soc-wcd9304.ko
kernel/sound/soc/codecs/snd-soc-wcd9310.ko
kernel/sound/soc/codecs/snd-soc-msm-stub.ko
kernel/sound/soc/msm/snd-soc-qdsp6.ko
kernel/sound/soc/msm/snd-soc-hostless-pcm.ko
kernel/sound/soc/msm/snd-soc-mdm9615.ko
kernel/sound/usb/snd-usb-audio.ko
kernel/sound/usb/snd-usbmidi-lib.ko
kernel/net/dns_resolver/dns_resolver.ko
kernel/net/ipv4/xfrm4_mode_beet.ko
kernel/net/ipv4/inet_lro.ko
kernel/net/ipv4/tunnel4.ko
kernel/net/ipv4/xfrm4_mode_transport.ko
kernel/net/ipv4/xfrm4_mode_tunnel.ko
kernel/net/ipv4/inet_diag.ko
kernel/net/ipv4/tcp_diag.ko
kernel/net/ipv4/tcp_cubic.ko
kernel/net/ipv6/ipv6.ko
kernel/net/ipv6/ah6.ko
kernel/net/ipv6/esp6.ko
kernel/net/ipv6/xfrm6_mode_transport.ko
kernel/net/ipv6/xfrm6_mode_tunnel.ko
kernel/net/ipv6/xfrm6_mode_beet.ko
kernel/net/ipv6/sit.ko
kernel/net/ipv6/inet6_hashtables.ko
kernel/net/packet/af_packet.ko
kernel/net/sched/sch_htb.ko
kernel/net/sched/sch_prio.ko
kernel/net/sched/cls_fw.ko
kernel/net/sched/cls_basic.ko
kernel/net/sched/cls_cgroup.ko
kernel/net/sunrpc/sunrpc.ko
kernel/net/sunrpc/auth_gss/auth_rpcgss.ko
kernel/net/unix/unix.ko
kernel/lib/bitrev.ko
kernel/lib/crc-ccitt.ko
kernel/lib/crc16.ko
kernel/lib/crc32.ko
kernel/lib/libcrc32c.ko
kernel/lib/lzo/lzo_compress.ko
kernel/lib/lzo/lzo_decompress.ko
kernel/lib/zlib_deflate/zlib_deflate.ko
kernel/lib/zlib_inflate/zlib_inflate.ko
It looks a bit confusing to me, there is a mkfs.minix but no filesystem for minix.
There are filesystems in the kernel (ext2, ext3, ext4, vfat, btrfs, …) but there is no mkfs support.
If there is kernel builtin fs support for ext4, how to format the partition without corresponding mkfs?
How to format and mount a MMC card on a AR7, which filesystem to use and how to mount it?
Br,
Martin…
esun
November 17, 2014, 11:31pm
4
It looks like vfat won’t work because ‘codepage cp437 not found’. However this will be fixed in the next release of Yocto.
I was able to mount my MMC card by formatting them as EXT filesystem.
e.g
On host machine, format MMC card using mkfs.ext2
Transfer mmc card to device again and try ‘mount /dev/mmcblk0p1 /media/card/’ again
Enoch
mkupke
November 18, 2014, 1:36pm
5
Hi esun,
yes you’re right…that works. It’s a bit tricky and confusing, because offering a mkfs.minix without support for minix filesystem. On the other hand no mkfs (make filesystem) for ext2, ext3, ext4, btrfs, vfat or whatever, but support for the filesystem within the kernel.
Okay…something you need to know. I guess it’s because of the the early stadium of the EvalBoard AR7, it’s still under development and more in beta state.
Thanks a lot for your answer.
Br,
Martin…
