If I have to fire only one timer, I agree with you, it’s much easier to use global variables.
But let’s see another scenario: let’s suppose a timer is fired by a command that wants to do something with its argument, i.e. a minute later. I think to somenting like AT+DELAYPRINT=5,“hello world” that writes a “hello world” five seconds later…
You could have, at any time, more than one timer waiting for its execution, each one with its different argument.
In that case I think that using the context can be easier than using global variables.
My case is that I’m using a timer to create a data input timeout.
I create the timer, and put the current state into the context variable. If more data is recieved BEFORE the timer fires, the timeout timer has to be cancelled and then restarted - but the reference to the context variable is not available so the restart routine cannot release the memory, thus creating a memory leak. This makes using the context variable useless for me as the timer will not always timeout so the handler will not be called - and also means that I cannot reuse the same timer handler for multiple timeouts as I have to use a different global variable for each current state I wish to deal with.
And you can’t use Automatic variables (i.e. local variables declared in a function) as the memory is undefined once the function goes out of scope.
It’s ugly and annoying.
I’ve also recieved advice from Wavecom to use global variables as the context when calling timers.
Oh yes - especally in an operating system/environment that is fundamentally event driven and busy-wait loops are not only frowned upon, but impossible to do without tripping the watchdog timer. (As they should do!).
Still, being able to restart a timer still wouldn’t solve my immediate problem, as I may never hit the timer handler if the comms is closed before a timeout occurs and the timer is manually unsubscribed.
Handling the context memory in the same fashion as memory in wm_lst() is (i.e. default to using adl_memRelease(), or user override with user defined function at list creation time) would be ideal.
Bump: Wavecom - please add this to the list of ‘TODO’ for upcoming versions of openAT.
If you know how to use C++ TR1 shared_ptr, then all problems you memtioned will be gone. Or you can use any smart pointer available in WEB. The latest M2M studio supports C++ and STL although it may have some problems when using C++ in ADl applications.
