ADL Get memory Error using wip_read
Hi to all!!, Im recieving this trace while im sendig a big file using the wip_read function.
“ADL Get memory…”
As far as the data came and the WIP READ event shows up i read the data from the recieve buffer, so i dont know what im doing wrong.
Can anyone help me?. Thanks!!.
Not based on the very little information you’ve given!
You presumably have the source code, so you must look it it to find what could cause that trace!
Thanks awneil!, i solved it!. It was a bad use of the getmem funtion that was making this exception.
Thanks a lot!!!
