In RTE (VC++ 6.0 for me), I find adl_adWrite() function is not really executed correctly.
If I call adl_adWrite() to write a small amount of data, e.g. 30 bytes, the return code is OK, but then if I call adl_adRead() to get back data I always get “FF” contents…
Only after I call adl_adFinalize() , or called adl_adWrite() for many times to make the adl_adRead() can get correct data. This make me need to debug my program using target mode (downloading .dwl file…), wasting more time.
Thank you for your answer , i called adl_adFinalize() juste befor rading data and i have the same problem , adl_adFinalize() is used just to make Read only data.
i think if a problem of adl_adFinalize() , it will be not work also in mode release .
