Hello!
Another big problem with UART - it seems that data sent with 7e1 frames (7 data bits, 1 stop, even parity) has wrong parity bit values.
This is my example code - I am sending some data over UART2 - when the frame is set to 8e1 data are sent correctly. But when it is set to 7e1 I get the data but with “frame error” (HTerm 0.6.5 shows frame errors). I suppose it is a parity error.
#include "adl_global.h"
#define SIGMAPACKAGE ":013A0000C5\r\n"
const u16 wm_apmCustomStackSize = 1024;
static s8 fcmHandle;
void SendString ( ascii * StringToSend );
void SendMessage_TimerHandler ( u8 ID )
TRACE (( 1, "Embedded : Send Message" ));
//adl_fcmSendData(fcmHandle,MESSAGE, sizeof(MESSAGE)-1);
SendString(SIGMAPACKAGE);
//adl_atSendResponse ( ADL_AT_UNS, "\r\nHello World from Open-AT\r\n" );
bool fcmCtrlH ( u8 Event )
bool bReturn = TRUE;
TRACE (( 1, "V24 event %d", Event ));
// Switch on event
switch ( Event )
case ADL_FCM_EVENT_FLOW_OPENNED :
adl_fcmSwitchV24State ( fcmHandle, ADL_FCM_V24_STATE_DATA );
TRACE (( 1, "Switch to data" ));
break;
case ADL_FCM_EVENT_RESUME :
TRACE (( 1, "Resume Data Flow"));
break;
case ADL_FCM_EVENT_MEM_RELEASE :
TRACE (( 1, "Data are sent"));
break;
return bReturn;
/* Function : fcmDataH */
bool fcmDataH ( u16 DataLen, u8 * Data )
/* Scan received string */
u8 i;
ascii * RecString = adl_memGet ( ( u16 ) ( DataLen ) );
TRACE (( 1, "V24DataHandler begin"));
wm_memcpy ( ( ascii * ) RecString, ( ascii * ) Data, DataLen );
DUMP ( 2, RecString, DataLen);
adl_memRelease ( RecString );
return TRUE;
bool Res_WMFM1_Handler ( adl_atResponse_t *paras ) {return TRUE;}
bool Res_IPR_Handler( adl_atResponse_t *paras ) {return TRUE;}
bool Res_IPR_Handler2( adl_atResponse_t *paras ) {return TRUE;}
bool Res_IPR_Handler1( adl_atResponse_t *paras ) {
TRACE (( 1, "(evh_sim) fcm handler create" ));
fcmHandle = adl_fcmSubscribe( ADL_FCM_FLOW_V24_UART2, fcmCtrlH, fcmDataH );
return TRUE;
adl_fcmDataBlock_t *BlockToSend;
s32 sReturn;
TRACE (( 1, "SendString "));
/* Build block to send */
BlockToSend = adl_memGet ( ( u16 ) ( sizeof ( adl_fcmDataBlock_t ) + wm_strlen ( StringToSend ) ) );
BlockToSend->DataLength = wm_strlen ( StringToSend );
wm_memcpy ( ( ascii * ) BlockToSend->Data, StringToSend, wm_strlen ( StringToSend ) );
/* Send Block */
sReturn = adl_fcmSendDataExt ( fcmHandle, BlockToSend );
TRACE (( 1, "Submit data : %d", sReturn ));
if ( sReturn == FALSE )
TRACE (( 1, "No more credit ; wait for resume" ));
/* Block sent, but flow not ready to send more data */
return;
else
// Wait for resume
TRACE (( 1, "String saved but not sent : wait for resume" ));
/* Function : adl_main */
TRACE (( 1, "Embedded : Appli Init" ));
adl_atCmdCreate( "AT+WMFM=0,1,2", FALSE, Res_WMFM1_Handler, "*", NULL ); //Activate UART2
adl_atCmdCreate( "AT+IPR=19200", ADL_AT_PORT_TYPE( ADL_AT_UART2, FALSE ),
Res_IPR_Handler, "*", NULL );
adl_atCmdCreate( "AT+IFC=0,0", ADL_AT_PORT_TYPE( ADL_AT_UART2, FALSE ),
Res_IPR_Handler2, "*", NULL );
adl_atCmdCreate( "AT+ICF=5,1", ADL_AT_PORT_TYPE( ADL_AT_UART2, FALSE ),
Res_IPR_Handler1, "*", NULL ); // 2,1 = 8e1, 5,1 = 7e1
adl_tmrSubscribe ( TRUE, 20, ADL_TMR_TYPE_100MS, SendMessage_TimerHandler );
In red are bytes with error. These first weird bytes are unsolicited messages (witch 8n1 115200 I suppose) which I can’t disable (see: viewtopic.php?f=15&t=2220).
Change “AT+ICF=5,1” to “AT+ICF=2,1” in code and there is no errors, but I must have 7e1 data transmission
