[73xx/74xx] confuse on RF MIMO
Hi
I have read 73xx/74xx PTS, I found the spec say the antena is 2x2 MIMO.
As far as I know, the module is 1 down-link and 2 up-link, but MIMO means Multi-input Multi-output.
Does it have Multi-output? or someone can enplane it.
Many thanks
Just keeping it simple the unit has a single transmitter and two receivers, you can see this in the RF block diagram in the PTS.
Hi
Thanks for your information.
So your means the MIMO is point in RF main?
Because the RF main have as below:
TX_LB1, TX_LB2 , TX_LB3, TX_LB4, TX_MB2, TX_MB3
PRX_LB1, PRX_LB2, PRX_LB3, PRX_MB1, PRX_MB2, PRX_MB3, PRX_HB.
Is it correct?
Are you referring to the diagram in the PTS?
