XON/XOFF flow control
Hiya,
Don’t feel bad about not being able to find the doco. SiWi have buried it deep within the Developer Studio bundle and expect you to access it from within DS. There’s been a number of discussions about the problems with this method, but nothing has changed.
The first thing I do when I install DS is to go hunting for the doco and put the PDF’s somewhere useful (so I can have DS on one monitor, and the doco on another!).
You’ll need to install Developer Studio. My version is installed into C:\OpenAT-DS-2.2.1 - your location may vary.
Then, go looking for the following directory under the base install (all one line):
Embedded Software\com.wavecom.openat.ide.spm.lib.os.model.6.52.0.201306271400_6.52.0.201306271400\resources\doc
Note that the ‘6.52.xxxx’ is the firmware version - this changes from release to release.
In the ‘Doc’ folder, you should find the ‘ADL_User_Guide.pdf’, which is the document I referred to above. There will be a version of this for each different version of the firmware - it’s important to read the right version for the firmware you are using as there are subtle changes between versions.
Note that the AT commands guide is available in a similar manner - look for the ‘xxx.fw.model.xxx’ directories in the same ;Embedded Software’ directory.
Hope this helps somewhat.
ciao, Dave
