Firmware install command => fwdwl-litearm -f /fw/Verizon/ -e 1
/fw/Verizon/ contains
SWI9X30C_02.33.03.00.cwe, SWI9X30C_02.33.03.00_VERIZON_002.079_001.nvuError Log
GobiSerial driver ttyUSB0: GobiSerial converter now disconnected from ttyUSB0
Send ZERO CONF FAIL!
GobiSerial 6-1:1.0: device disconnected
GobiSerial driver ttyUSB1: GobiSerial converter now disconnected from ttyUSB1
GobiSerial 6-1:1.2: device disconnected
GobiSerial driver ttyUSB2: GobiSerial converter now disconnected from ttyUSB2
GobiSerial 6-1:1.3: device disconnected
GobiNet 6-1:1.8: eth3: unregister ‘GobiNet’ usb-0002:04:00.0-1, GobiNet Ethernet Device
usb 6-1: reset SuperSpeed USB device number 2 using xhci_hcd
xhci_hcd 0002:04:00.0: xHCI xhci_drop_endpoint called with disabled ep ee8d34ac
xhci_hcd 0002:04:00.0: xHCI xhci_drop_endpoint called with disabled ep ee8d3480
xhci_hcd 0002:04:00.0: xHCI xhci_drop_endpoint called with disabled ep eef66598
xhci_hcd 0002:04:00.0: xHCI xhci_drop_endpoint called with disabled ep eef6656c
xhci_hcd 0002:04:00.0: xHCI xhci_drop_endpoint called with disabled ep eef66658
xhci_hcd 0002:04:00.0: xHCI xhci_drop_endpoint called with disabled ep eef66540
xhci_hcd 0002:04:00.0: xHCI xhci_drop_endpoint called with disabled ep eef66118
xhci_hcd 0002:04:00.0: xHCI xhci_drop_endpoint called with disabled ep eef6662c
xhci_hcd 0002:04:00.0: xHCI xhci_drop_endpoint called with disabled ep eef66600
xhci_hcd 0002:04:00.0: xHCI xhci_drop_endpoint called with disabled ep eef660ec
xhci_hcd 0002:04:00.0: xHCI xhci_drop_endpoint called with disabled ep eef660c0
GobiNet 6-1:1.8: eth3: register ‘GobiNet’ at usb-0002:04:00.0-1, GobiNet Ethernet Device, 9e:fd:9b:88:3f:08
USB Speed : USB 3.0
GobiSerial 6-1:1.3: GobiSerial converter detected
usb 6-1: GobiSerial converter now attached to ttyUSB0
GobiSerial 6-1:1.2: GobiSerial converter detected
usb 6-1: GobiSerial converter now attached to ttyUSB1
GobiSerial 6-1:1.0: GobiSerial converter detected
usb 6-1: GobiSerial converter now attached to ttyUSB2
creating qcqmi0
RawIP mode
USB Speed : USB 3.0
creating qcqmi0
RawIP mode
USB Speed : USB 3.0
creating qcqmi0
RawIP mode
USB Speed : USB 3.0
creating qcqmi0
RawIP mode
GobiSerial driver ttyUSB2: usb_serial_generic_submit_read_urb - usb_submit_urb failed: -2
xhci_hcd 0002:04:00.0: xHCI host not responding to stop endpoint command.
xhci_hcd 0002:04:00.0: Assuming host is dying, halting host.
xhci_hcd 0002:04:00.0: HC died; cleaning up
usb 6-1: USB disconnect, device number 2
This problem was not observed if EM7455 connects to EHCI (USB2.0)
The EM7455 is attached to PCIe x1 through µPD720201 USB host controller.
Hi akn
Please try it with supper USB speed (USB 3.0) (AT!USBSPEED=1).
AT!ENTERCND=”A710”
AT!USBSPEED=1
AT!RESET
