Is WP85 WiFi support available for external users today? If not, what is the anticipated release date. Thanks, Mark
WP85 can be used as WiFi AP. If you use mangOH or mangOH Green, the driver for the WiFI chips on those boards are already integrated in the WP85. If you use a different WiFi chip, you’ll have to integrate the driver. Please refer mangoh.io for details on the mangOH boards. You can also refer the embedded Legato framework that supports a WiFi service. The forums for legato and mangoh have quite a lot of information on this topic. You can also look at the mangoh github for code samples. https://github.com/mangOH/mangOH
