Could you provide the answer of the “cm info” command?
If you are using AirPrime WP8548 module on mangOH board (PCB REV 2) then it seems that the WM8944 audio codec I2C lines are not connected.
See the mangOH schematics (REV 2), on Sheet #5 you can see that R560 and R561 resistors are labeled as “DNI” (do not install).
This will explain the error messages about missing device at 0x1a address.
