wm_ioSerialSwitchState();
Hi everybody
I am having a problem switching UART1 to data_mode.
wm_ioSerialSwitchState(WM_IO_UART1,WM_IO_SERIAL_DATA_MODE);
if (wm_fcmOpen(WM_FCM_V24_UART1,120) == 0)
	wm_sprintf(texta,"\r\nSuccess\r");
	wm_atSendUnsolicitedExternalApp ( ( u16 ) ( wm_strlen ( texta ) + 1 ), texta );
else {
wm_sprintf(textb,"\r\nFailure\r");
	wm_atSendUnsolicitedExternalApp ( ( u16 ) ( wm_strlen ( textb ) + 1 ), textb );
The fcmopen(); succeeds. But the:
case WM_IO_SERIAL_SWITCH_STATE_RSP :
	wm_sprintf(textc,"\r\nSwitched\r");
	wm_atSendUnsolicitedExternalApp ( ( u16 ) ( wm_strlen ( textc ) + 1 ), textc );
break;
isn’t trrigered. Why isn’t it triggered?
Thanks, Stephan
Hi Stephan,
I don’t know for sure since I am using ADL… Have you tried to open the flow first, and then switch the state? That’s what I doing in ADL, and that works fine…
Best Regards,
Jan
Hi again,
Maybe the problem is that you are switching the UART on which you try to output to with wm_atSendUnsolicitedExternalApp(). Since it is now in data mode, maybe you should use the fcm functions instead to output data on the UART1 port?
Best Regards,
Jan
