I am attempting to set up my GL6100 as a transparent RS232-TCP
For this, I am using the code in WIPSOFT examples, specifically this code:
AT+WIPCFG=1
OK //start IP stack
AT+WIPBR=1,6
OK //open GPRS bearer
AT+WIPBR=2,6,11,”APN name”
OK //set APN name of GPRS bearer
AT+WIPBR=2,6,0,”user name”
OK //set user name
AT+WIPBR=2,6,1,”passwd”
OK //set password
AT+WIPBR=4,6,0
OK //start GPRS bearer
AT+WIPCREATE=2,1,”ip addr”,80 //create a TCP client towards peer IP device @ “ip //addr”, port 80.
//all parameters and IP stack behavior are OK.
+WIPREADY: 2,1
//unsolicited: the TCP client socket is connected //to the peer
AT+WIPDATA=2,1,1
CONNECT
//exchange data on socket idx 1:
//read, write
//switch to AT mode
AT+WIPCLOSE=2,1
It all works out until I type the AT+WIPDATA command. I get no return from this (and obviously the connection is not established".
