Hi
As per your explanation ideally the watchdog reset should not happen.May be the call to adl_wdPut2Sleep is getting missed out somewhere. Are your task event driven?
I am asking this because if the event for the particular task(in which adl_wdPut2Sleep is given) doesnt come then adl_wdPut2Sleep will never be executed and this might be the reason for the watchdog reset.
thanks for your answer. Yes, this task is event driven (a proprietary software timer driven by TCU service and Message service activates the task), but traces show us that the task and adl_wdPut2Sleep() is called in time - even if the watchdog resets the system a few seconds later. Experimentally we implemented “infinite” loops (duration about 30 sec) in various tasks - no problem, OAT is serving the watchdog correctly in the time given by adl_wdPut2Sleep(). Via IO-Pins and oscilloscope I also checked the interrupts - there is no dead lock.
Is it possible, that a software bug somewhere in our application (a bad pointer or something else) could trigger the watchdog?
After removing all C++ exceptions and setting the compiler flag “-fno-exceptions”, the software crashes are gone.
Background: Our project contains Lua with a special Lua scheduler (written in C) and special Lua functions. Lua internally uses setjump/longjump to implement its exception mechanism. Some implementations of C++ exception handling also use setjump/longjump. In particular our Lua scheduler heavily uses the Lua-API and had try-catch blocks (also throw statements). Maybe both setjump/longjump parts didn’t play together perfectly…
