I wanted to run Fasttrack as a modem for a Mobile Device (Windows CE 6.0 / Processor: ARM920T-PXA3xx). There are even drivers for respective devices (Windows CE 6.0 , Processor ARM920) but if I execute the CAB file on my mobile device it gives me a error message:
“The application cannot run on this device type. Please install the application specific of this device type.”
Maybe there are some problems with certificates? But I have problems to connect the device directly to my PC, so it I don´t no how to change security options on the device itself.
I would be glad if you could help me / give me a hint.
After installing the Windows CE Generic ARM driver for Fasttrack on my mobile device I tried to connect the Fasttrack via Mini-USB to the mobile device in order to use it as a Modem… if I want to set up the connection I get following error:
“The modem is not plugged in or is out of service. Connect a modem to your computer and try again.”
Do I have to change any setting (baudrate or TCP setting? before I´ve used the device via Serial Port and it worked very well!)
Is your Windows CE device USB port a Master device? Mini USB is usually only for B type slave connections - so you usually can’t connect two Mini-B device/connectors together and get a valid link. Only exception (that I know of) is for USB ‘On The Go’ - which requires special master and slave devices. The Fastrack doesn’t support USB ‘On The Go’.
