My problem with UART2 is that I can’t see the data in Terminal Emulator. I saw the other threads with regard to UART2 but i can’t find the answer.
ADL_FCM_EVENT_MEM_RELEASE is the case in which the data is sent, but i don’t see the data in Terminal Emulator. I’ m using Fast Track SUpreme 20.
This my code:
static s8 FCM;
static s8 FCMV24;
static s8 fcmData;
static s8 Ipr, Wmfm;
adl_fcmFlow_e flow = ADL_PORT_UART2;
bool HandleWmfmUart2(adl_atResponse_t *response);
void SendData(u8 Id)
u8 data[10] = “asdasd”;
u16 dataLen = sizeof(data);
fcmData = adl_fcmSendData(FCM, data, dataLen);
bool CtrlHandler(adl_fcmEvent_e event)
switch( event )
case ADL_FCM_EVENT_FLOW_OPENNED :
TRACE(( 1, “ADL_FCM_EVENT_FLOW_OPENNED\n”));
FCMV24 = adl_fcmSwitchV24State(FCM, ADL_FCM_V24_STATE_DATA);
TRACE(( 1, “adl_fcmSwitchV24State = %d”, FCMV24));
break;
case ADL_FCM_EVENT_V24_DATA_MODE :
TRACE(( 1, "ADL_FCM_EVENT_V24_DATA_MODE\n"));
adl_tmrSubscribe(TRUE, 100, ADL_TMR_TYPE_100MS, (adl_tmrHandler_t)SendData);
break;
case ADL_FCM_EVENT_V24_AT_MODE :
case ADL_FCM_EVENT_V24_AT_MODE_EXT:
TRACE(( 1, "ADL_FCM_EVENT_V24_AT_MODE\n"));
FCMV24 = adl_fcmSwitchV24State(FCM, ADL_FCM_V24_STATE_AT);
break;
case ADL_FCM_EVENT_FLOW_CLOSED:
TRACE(( 1, "ADL_FCM_EVENT_FLOW_CLOSED\n"));
adl_fcmUnsubscribe(FCM);
break;
case ADL_FCM_EVENT_RESUME :
TRACE(( 1, "ADL_FCM_EVENT_RESUME\n"));
break;
case ADL_FCM_EVENT_MEM_RELEASE :
TRACE(( 1, "ADL_FCM_EVENT_MEM_RELEASE\n"));
break;
bool DataHandler(u16 DataLen, u8 * Data)
TRACE(( 1, “DataHandler\n”));
return TRUE;
bool HandleWmfmUart2(adl_atResponse_t * response)
TRACE (( 1, “HandleWmfmUart2Enable\n” ));
FCM = adl_fcmSubscribe(flow, CtrlHandler, DataHandler);
TRACE(( 1, “adl_fcmSubscribe= %d”, FCM));
return FALSE;
bool HandleIPR(adl_atResponse_t * response)
TRACE(( 1, “HandleIPR\n”));
return FALSE;
TRACE (( 1, “Embedded Application : FCM\n” ));
Wmfm = adl_atCmdCreate("AT+WMFM=0,1,2", FALSE, HandleWmfmUart2, "*", NULL);
TRACE(( 1, "adl_atCmdCreate(AT+WMFM)= %d", Wmfm));
Ipr = adl_atCmdCreate("AT+IPR=115200", ADL_AT_PORT_TYPE(flow, FALSE), HandleIPR, "*", NULL);
TRACE(( 1, "adl_atCmdCreate(AT+IPR)= %d", Ipr));
