hi all,
firts i use uart2 as GPIO to generate the desired wave,then use uart2 to send data.The first step is ok now.But uart2 is always not send any data.
the code is below.And the taget monitoring tool results are as follows:
Trace IP 1 Embedded Application : Main
Trace IP 1 K Line
Trace IP 1 value w_fcm : 0
Trace IP 1 cmd_RspHandler_IPR
Trace IP 1 HandleWmfmUart2Disable
Trace IP 1 iowrite return value is 5
Trace IP 1 HandleWmfmUart2Enable
Trace IP 1 Event Handler : 0
Trace IP 1 V24 Flow Opened
Trace IP 1 Event Handler : 2
Trace IP 1 Switched to data mode
Trace IP 1 SenddataReturn value is 0 //the return value is ok!!
Trace IP 1 Send data
Trace IP 1 Event Handler : 7
Trace IP 1 V24 Flow Closed
If anyone can give me a hand ,i will really appreciate it.
u32 wm_apmCustomStack [ 256 ];
const u16 wm_apmCustomStackSize = sizeof ( wm_apmCustomStack );
u32 i=0;
char* string[100];
s8 GPIO1_Handle;
s8 writereturn;
s8 SenddataReturn;
s8 w_fcm;
s8 StartCommun[5]={0x81,0x10,0xf1,0x81,0x03};
adl_ioProductTypes_e productype;
s32 GetTime(void);
void OATSleep (u16 msec);
bool FCM_V24_data_Handler(u16 datalength, u8 *data);
bool FCM_V24_ctrl_Handler(u8 event);
bool cmd_RspHandler_IPR(adl_atResponse_t * params);
bool HandleWmfmUart2Enable(adl_atResponse_t *response);
bool HandleWmfmUart2Disable(adl_atResponse_t *response);
void SendData(void);
//const wm_ioConfig_t myconfig[]={WM_IO_Q24PLUS_GPO_1,0,0,1};
/* Local variables */
/* Local functions */
/* Function : adl_main */
/* Object : Customer application initialisation */
/* Variable Name |IN |OUT|GLB| Utilisation */
/* InitType | | | | Application start mode reason */
s8 bUARTok = -1;
TRACE (( 1, "Embedded Application : Main" ));
TRACE (( 1, "K Line" ));
productype =adl_ioGetProductType();
bUARTok = adl_atCmdCreate("AT+WMFM=0,0,2", FALSE, HandleWmfmUart2Disable, "*", NULL); //disable uart2
bUARTok = adl_atCmdCreate("AT+WMFM=0,1,2", FALSE, HandleWmfmUart2Enable, "*", NULL);// enable uart2
adl_atCmdCreate("AT+IPR=10400", ADL_AT_PORT_TYPE( ADL_AT_UART2, FALSE ), (adl_atRspHandler_t) cmd_RspHandler_IPR, "*", NULL);
adl_atCmdCreate("AT+ICF=3,4", ADL_AT_PORT_TYPE(ADL_AT_UART2, FALSE), (adl_atRspHandler_t) cmd_RspHandler_IPR, "*", NULL );
if(!bUARTok)
TRACE (( 1, "value w_fcm : %d ", w_fcm ));
if(w_fcm < 0)
TRACE (( 1, "UART2 can't opened" ));//ErroR
s32 GetTime(void)
adl_rtcTime_t time;
s32 milliseconds;
adl_rtcGetTime(&time);
milliseconds = (s32)1000*time.SecondFracPart/32768;
milliseconds += (s32)1000*time.Second;
milliseconds += (s32)(60*1000)*time.Minute;
milliseconds += (s32)(60*60*1000)*time.Hour;
milliseconds += (s32)(24*60*60*1000)*time.Day;
return milliseconds;
s32 initial_time;
u16 diff = 0;
initial_time = GetTime();
while (diff<msec)
diff = GetTime() - initial_time;
s8 returnValue;
char string1[100];
wm_sprintf(string1, "(Uart1DataHandler)Bytes Received: %d\r\n", datalength);
TRACE((1,string1));
//adl_fcmSendData(w_fcm, string1, datalength);
//adl_atSendResponse(ADL_AT_RSP,string1);
returnValue = adl_fcmSendData(w_fcm, data, datalength);
if (returnValue < 0)
wm_sprintf(string1, "(Uart1DataHandler) adl_fcmSendData() failed. returnValue=%d\r\n", returnValue);
TRACE((1,string1));
return TRUE;
TRACE (( 1, "Event Handler : %d", event ));
switch (event)
case ADL_FCM_EVENT_FLOW_OPENNED:
TRACE (( 1, "V24 Flow Opened" ));
adl_fcmSwitchV24State(w_fcm, ADL_FCM_V24_STATE_DATA);
break;
case ADL_FCM_EVENT_V24_DATA_MODE :
TRACE (( 1, "Switched to data mode" ));
//wm_sprintf(string, "%d", 1);
//adl_fcmSendData(w_fcm, (u8 *)StartCommun, 5);
adl_tmrSubscribe(FALSE,1,ADL_TMR_TYPE_100MS,SendData);
break;
case ADL_FCM_EVENT_V24_AT_MODE :
TRACE (( 1, "Switched to at mode" ));
// Unsubscribe V24 flow
adl_fcmUnsubscribe(w_fcm);
break;
case ADL_FCM_EVENT_FLOW_CLOSED:
// adl_memRelease(RECEIVE_DATA);
TRACE (( 1, "V24 Flow Closed" ));
break;
case 7:
break;
return TRUE;
TRACE (( 1, "cmd_RspHandler_IPR" ));
return FALSE;
TRACE (( 1, "HandleWmfmUart2Enable" ));
w_fcm = adl_fcmSubscribe(ADL_PORT_UART2,FCM_V24_ctrl_Handler,FCM_V24_data_Handler);
return(FALSE);
TRACE (( 1, "HandleWmfmUart2Disable" ));
GPIO1_Handle = adl_ioSubscribe ( ADL_IO_Q24PLUS_GPO_2, 0,0xFFFFFFFF,0,NULL); // GpioHandler ,output,value=1
TRACE((1,"iowrite return value is %d",GPIO1_Handle));
OATSleep(300);
adl_ioUnsubscribe(GPIO1_Handle);
OATSleep(20);
OATSleep(18);
return(FALSE);
void SendData(void)
SenddataReturn=adl_fcmSendData(w_fcm, (s8*)"23", 2);
TRACE((1,"SenddataReturn value is %d",SenddataReturn));
TRACE (( 1, "Send data" ));
