amat79
January 28, 2007, 3:04pm
1
Hi, All!
Maybe someone will help me… I’m using Q2686H OpenAT 4.10. Im my program I subscribed FCM Flow to UART1 and it works fine. Now I need to recive incoming CSD call and make a direct channel to UART1. Is it correct to use something like (I tryed this code but didn’t recive V24DataHandler):
(skip)
adl_callSubscribe (Call_Handler);
(skip)
s8 Call_Handler(u16 Event, u32 Call_ID)
switch (Event)
case ADL_CALL_EVENT_RING_DATA:
adl_callAnswer();
break;
case ADL_CALL_EVENT_ANSWER_OK:
V24Handle = adl_fcmSubscribe ( USED_FLOW, V24CtrlHandler, V24DataHandler );
break;
bool V24CtrlHandler ( u8 Event )
switch ( Event )
case ADL_FCM_EVENT_FLOW_OPENNED :
adl_fcmSwitchV24State ( V24Handle, ADL_FCM_V24_STATE_DATA );
break;
case ADL_FCM_EVENT_RESUME :
break;
case ADL_FCM_EVENT_MEM_RELEASE :
break;
case ADL_FCM_EVENT_FLOW_CLOSED:
break;
return TRUE;
bool V24DataHandler ( u16 Length, u8 * Data )
adl_fcmSendData(UART1_Handle,Data, Length);
Best regards!
sefer
January 31, 2007, 9:38am
2
V24DataHandler is called when data “arrive” to UART1 to the RX pin , not when you have data from a data call.
amat79
February 2, 2007, 3:13pm
3
Hi, sefer!
Why do you think that V24DataHandler is called from UART1?
Is this string wrong?
Best regards!
awneil
February 2, 2007, 3:39pm
4
amat79:
Hi, sefer!
Best regards!
It is impossible to say which Flow is subscribed here as you haven’t shown your definition for USED_FLOW
So, which Flow do you subscribe for V24Handle ?
amat79
February 3, 2007, 11:24am
5
Hi, awneil!
My definition of USED FLOW is:
#define USED_FLOW ADL_FCM_FLOW_GSM_DATA
coan
February 4, 2007, 12:32pm
6
I think you have the same problem that I had.
Use at+wmfm=1,1,0,0 while in (wopen=0) save and then open application(see also documentation)
See also this
wavecom.com/modules/movie/sc … php?t=1078
awneil
February 5, 2007, 11:15am
7
awneil:
Are you deliberately trying to confuse everyone?!
When you sunscribe to the GSM_DATA Flow, why do you name the Handle “V24 Handle” and the handlers “V24 CtrlHandler” and “V24 DataHandler”
Would it not be a whole lot clearer to write:
GSM_DATA_Handle = adl_fcmSubscribe ( ADL_FCM_FLOW_GSM_DATA, GSM_DATA_CtrlHandler, GSM_DATA_DataHandler );
amat79
February 5, 2007, 5:38pm
8
Sorry, I used identificators form Wavecom Remote_Terminal example.
