I found a problem with wildcard TLS certificates (ex: *.domain.com).
HL6528x respond with error 13 (SSL error…) on SSL handshake.
Do you have an idea about that ?
Thank you
Hi JCzic,
HL6528 TLS Client supports only TLS 1.0, not TLS1.1 and TLS1.2.
If the server need algorithm like sha256(TLS 1.2), then module will fail to access.
Ok thank you
I suppose that *.google.com support all TLS versions to works with any machine?
Hi JCzic,
Could you share with me your AT logs?
SSL error (13) with HL6528x and now, internal trouble (5) with HL85xxx on https://hc2.fr or https://www.hc2.fr.
Works on https://www.google.fr
Logs :
AT+KHTTPSCFG=1,“hc2.fr”
+KHTTPSCFG: 6
+KHTTPS_IND: 6,1
AT+KHTTPSGET=6,"/"
NO CARRIER
+KHTTPS_ERROR: 6,5
Hi JCzic,
**Yes I see the +KHTTPS_ERROR : 0, 13 for HL6528. But it is old product and no maintainace now. **
HL8518 and HL8548 can work fine for “www.hc2.fr”.
Here’s my test logs:
ATI3
SIERRA HL6N,008.10.20CF.7445A
AT+KCNXCFG=1,“GPRS”,"cmnet"
AT+KHTTPSCFG=1,"www.hc2.fr"
+KHTTPSCFG: 0
AT+KHTTPSGET=0,"/"
ATI
HL8518
ATI3
RHL85xx.5.14.0.7.5.20171229.x6255
+KHTTPSCFG: 1
+KCNX_IND: 1,4,1
+KCNX_IND: 1,1,0
+KHTTPS_IND: 1,1
AT+KHTTPSGET=1,"/"
CONNECT
HTTP/1.1 200 OK
Cache-Control: no-cache
Content-Length: 19416
Content-Type: text/html
Last-Modified: Thu, 30 Aug 2018 23:42:49 GMT
Accept-Ranges: bytes
ETag: "eb6f1f29bb40d41:0"
Server: Microsoft-IIS/10.0
X-Powered-By: ASP.NET
Date: Fri, 22 Mar 2019 02:44:58 GMT
–EOF–Pattern–
+KHTTPS_IND: 1,3,19691,200,"OK"
ATI
HL8548-G
ATI3
RHL85xx.5.5.25.1.201809102043.x6250_1
+KHTTPSCFG: 1
+KCNX_IND: 1,4,1
+KCNX_IND: 1,1,0
+KHTTPS_IND: 1,1
AT+KHTTPSGET=1,"/"
CONNECT
HTTP/1.1 200 OK
Date: Thu, 21 Mar 2019 09:52:20 GMT
–EOF–Pattern–
Oky I see
Thank you and have a nice day!
