I have an application that sets up UART1 and GSM streams for FCM handling when a call comes in. If I don’t answer the call (cancel the atd before ‘CONNECT’) then the streams all close down properly and I can make another call.
If, however, I allow the session to connect the stream for the UART does not close, any ideas why?
Here’s a cut-down version of the code:
s8 CallEventHandler (u16 Event, u32 CallID)
	s8 ReturnValue=ADL_CALL_FORWARD;
	switch (Event)
		case ADL_CALL_EVENT_RING_DATA:
			if (adl_fcmIsAvailable(ADL_PORT_UART1)==TRUE)
				//Listen for local comms events
				UART_FlowControlHandle=adl_fcmSubscribe (ADL_PORT_UART1, (adl_fcmCtrlHdlr_f)UART_FCMControlHandler, (adl_fcmDataHdlr_f)UART_FCMDataHandler);
				if (UART_FlowControlHandle<0)
					OutputTraceAndNumber (1, "Failed to subscribe to UART flow control, response : ", UART_FlowControlHandle);
				//Listen for GSM comms events
				GSM_FlowControlHandle=adl_fcmSubscribe (ADL_PORT_GSM_BASE, (adl_fcmCtrlHdlr_f)GSM_FCMControlHandler, (adl_fcmDataHdlr_f)GSM_FCMDataHandler);
				if (GSM_FlowControlHandle<0)
					OutputTraceAndNumber (1, "Failed to subscribe to GSM flow control, response : ", GSM_FlowControlHandle);
				OutputTrace (1, "UART switched to data mode");
				OutputTrace (1, "Incoming data call, answering call ...");
				//This answers the call
				ReturnValue=ADL_CALL_NO_FORWARD_ATA;
			else
				OutputTrace (1, "Ignoring incoming call, UART unavailable");
			break;
		case ADL_CALL_EVENT_ANSWER_OK:
			//Call set up after a ADL_CALL_NO_FORWARD_ATA
			OutputTraceAndNumber (1, "Answered OK, speed : ", CallID);
			//Switch the UART to data mode
			adl_fcmSwitchV24State (UART_FlowControlHandle, ADL_FCM_V24_STATE_DATA);
			break;
	return ReturnValue;
void Hangup()
	//Switch back to 'AT mode'
	adl_fcmSwitchV24State (UART_FlowControlHandle, ADL_FCM_V24_STATE_AT);
	OutputTrace (1, "UART returned to 'AT' mode");
	//Release the flow control handle for UART
	adl_fcmUnsubscribe (UART_FlowControlHandle);
	OutputTrace (1, "UART stream unsubscribed");
	//Release the flow control handle for GSM
	adl_fcmUnsubscribe (GSM_FlowControlHandle);
	OutputTrace (1, "GSM stream unsubscribed");
bool GSM_FCMControlHandler (adl_fcmEvent_e Event)
	switch (Event)
		case ADL_FCM_EVENT_FLOW_CLOSED:
			OutputTrace (1, "GSM stream closed");
			Hangup();
			break;
	return TRUE;
bool GSM_FCMDataHandler (u16 DataLength, u8 *Data)
	OutputTraceAndNumber (2, "GSM:", DataLength);
	return TRUE;
bool UART_FCMDataHandler (u16 DataLength, u8 *Data)
	adl_fcmSendData (GSM_FlowControlHandle, Data, DataLength);
	return TRUE;
//---------------------------------------------------------------------------------Debug :
//Incoming call
Trace	L3RR	1	Unable to find the string of the remote trace in the file (ID = 875186)
Trace	IP	1	06/01/2000,19:14:44	UART switched to data mode
Trace	IP	1	06/01/2000,19:14:44	Incoming data call, answering call …
Trace	IP	1	06/01/2000,19:14:44	UART stream opened
Trace	IP	1	06/01/2000,19:14:44	GSM stream opened
Trace		1	Unable to find the string of the remote trace in the file (ID = 878588)
Trace	MMT	1	Unable to find the string of the remote trace in the file (ID = 872087)
//Hung the call
Trace	IP	1	06/01/2000,19:14:45	GSM stream closed
Trace	IP	1	06/01/2000,19:14:45	UART returned to ‘AT’ mode
Trace	IP	1	06/01/2000,19:14:45	UART stream unsubscribed
Trace	IP	1	06/01/2000,19:14:45	GSM stream unsubscribed
Trace	IP	1	06/01/2000,19:14:45	No carrier
Trace	IP	1	06/01/2000,19:14:45	Released ID
Trace	IP	1	06/01/2000,19:14:45	UART stream closed
//Another incoming call
Trace	IP	1	06/01/2000,19:14:54	UART switched to data mode
Trace	IP	1	06/01/2000,19:14:54	Incoming data call, answering call …
Trace	IP	1	06/01/2000,19:14:55	UART stream opened
Trace	IP	1	06/01/2000,19:14:55	GSM stream opened
Trace		1	Unable to find the string of the remote trace in the file (ID = 877977)
//This time we connect
Trace	IP	1	06/01/2000,19:15:07	Answered OK, speed : 9600
Trace	IP	1	06/01/2000,19:15:07	UART in V24 data mode
//Send +++ then an ATH
Trace	IP	2	06/01/2000,19:15:09	GSM:1
Trace	IP	2	06/01/2000,19:15:10	GSM:1
Trace	IP	1	06/01/2000,19:15:11	GSM stream closed
Trace	IP	1	06/01/2000,19:15:11	UART returned to ‘AT’ mode
Trace	IP	1	06/01/2000,19:15:12	UART stream unsubscribed
Trace	IP	1	06/01/2000,19:15:12	GSM stream unsubscribed
Trace	IP	1	06/01/2000,19:15:12	No carrier
Trace	IP	1	06/01/2000,19:15:12	Released ID
Trace	IP	1	06/01/2000,19:15:12	UART in V24 AT mode
//No UART closure!! The ADL_FCM_EVENT_FLOW_CLOSED isn’t called
