usa
1
ascii msg[255];
int value = 1;
wm_sprintf(msg, "Value: %d", value);
adl_atSendResponse(ADL_AT_UNS, msg);
//print "Value: 1"
//print "Value: 0" why??
Why after call wm_sprintf variable set to zero?
tobias
4
If that code is in the same function, then it doesn’t make sense at all.
You might want to check the value you use for stack allocation just to be sure it’s not too low. Problems with too small stack can be incredibly odd.
tobias
5
The open at version you mentioned…
What module is it for? I haven’t seen version numbers like that before myself.
