Hi, everyone!
We’re following the steps described in ReadMe.txt of Android 9 RIL and we followed every step. One of the steps was copy a lot of sepolicy files into Android. The files were:
- device.te,
- dhcp.te,
- file.te,
- file_contexts,
- init.te,
- netd.te,
- property_contexts,
- rild.te,
- sierra_config_ip.te,
- sierra_dhcpcd.te,
- hal_gnss_default.te,
- webview_zygote.te.
And we got the following error when we’re compiling:
FAILED: out/target/product/evk_8mm/obj/ETC/sepolicy_neverallows_intermediates/sepolicy_neverallows
/bin/bash -c "(rm -f out/target/product/evk_8mm/obj/ETC/sepolicy_neverallows_intermediates/sepolicy_neverallows ) && (ASAN_OPTIONS=detect_leaks=0 out/host/linux-x86/bin/checkpolicy -M -c 30 -o out/target/product/evk_8mm/obj/ETC/sepolicy_neverallows_intermediates/sepolicy_neverallows out/target/product/evk_8mm/obj/ETC/sepolicy_neverallows_intermediates/policy.conf )"
libsepol.report_failure: neverallow on line 31 of system/sepolicy/private/domain.te (or line 26731 of policy.conf) violated by allow netd sysfs:file { write open };
libsepol.report_failure: neverallow on line 1002 of system/sepolicy/public/domain.te (or line 11242 of policy.conf) violated by allow sierra_dhcpcd shell_exec:file { execute execute_no_trans };
libsepol.report_failure: neverallow on line 1002 of system/sepolicy/public/domain.te (or line 11242 of policy.conf) violated by allow sierra_dhcpcd sierra_dhcpcd_exec:file { execute entrypoint };
libsepol.report_failure: neverallow on line 1002 of system/sepolicy/public/domain.te (or line 11242 of policy.conf) violated by allow sierra_config_ip sierra_config_ip_exec:file { execute entrypoint };
libsepol.report_failure: neverallow on line 1002 of system/sepolicy/public/domain.te (or line 11242 of policy.conf) violated by allow sierra_config_ip toolbox_exec:file { execute execute_no_trans };
libsepol.report_failure: neverallow on line 1002 of system/sepolicy/public/domain.te (or line 11242 of policy.conf) violated by allow sierra_config_ip dhcp_exec:file { execute execute_no_trans };
libsepol.report_failure: neverallow on line 1002 of system/sepolicy/public/domain.te (or line 11242 of policy.conf) violated by allow sierra_config_ip shell_exec:file { execute execute_no_trans };
libsepol.report_failure: neverallow on line 1002 of system/sepolicy/public/domain.te (or line 11242 of policy.conf) violated by allow sierra_dhcpcd toolbox_exec:file { execute execute_no_trans };
libsepol.report_failure: neverallow on line 1002 of system/sepolicy/public/domain.te (or line 11242 of policy.conf) violated by allow sierra_dhcpcd dhcp_exec:file { execute execute_no_trans };
libsepol.report_failure: neverallow on line 870 of system/sepolicy/public/domain.te (or line 10993 of policy.conf) violated by allow sierra_dhcpcd dhcp_data_file:dir { ioctl read write getattr lock add_name remove_name search open };
libsepol.report_failure: neverallow on line 870 of system/sepolicy/public/domain.te (or line 10993 of policy.conf) violated by allow sierra_config_ip net_data_file:dir { search };
libsepol.report_failure: neverallow on line 870 of system/sepolicy/public/domain.te (or line 10993 of policy.conf) violated by allow sierra_dhcpcd net_data_file:dir { search };
libsepol.report_failure: neverallow on line 843 of system/sepolicy/public/domain.te (or line 10942 of policy.conf) violated by allow sierra_config_ip net_data_file:file { open };
libsepol.report_failure: neverallow on line 843 of system/sepolicy/public/domain.te (or line 10942 of policy.conf) violated by allow sierra_dhcpcd dhcp_data_file:file { create setattr lock map unlink rename open };
libsepol.report_failure: neverallow on line 843 of system/sepolicy/public/domain.te (or line 10942 of policy.conf) violated by allow sierra_config_ip dhcp_data_file:file { create setattr lock map unlink rename open };
libsepol.check_assertions: 15 neverallow failures occurred
Error while expanding policy
out/host/linux-x86/bin/checkpolicy: loading policy configuration from out/target/product/evk_8mm/obj/ETC/sepolicy_neverallows_intermediates/policy.conf
[ 0% 9/56693] build out/target/product/evk_8mm/obj/ETC/sepolicy.recovery_intermediates/sepolicy
out/host/linux-x86/bin/checkpolicy: loading policy configuration from out/target/product/evk_8mm/obj/ETC/sepolicy.recovery_intermediates/sepolicy.recovery.conf
out/host/linux-x86/bin/checkpolicy: policy configuration loaded
out/host/linux-x86/bin/checkpolicy: writing binary representation (version 30) to out/target/product/evk_8mm/obj/ETC/sepolicy.recovery_intermediates/sepolicy.tmp
Ps: we can’t disable SELinux.
Can someone help with this? Is that a new sepolicy files?
Thanks in advance!
