I am using a q2687rd module with R746 (R7.46.0.201108091301.Q2687RD 2216044 080911 13:01)
I need to send a uart break sequence on uart2 to reset a chip attached to this port.
Here is my code so far
sUartSettings_t Settings;
sUartFlowCtrl_t Fc;
Settings.identity = "UART2";
Settings.role = UART_ROLE_NM;
Settings.capabilities = NULL;
Settings.event_handlers =NULL; //&events;
Settings.interface = &pinterface2;
Settings.line_coding =NULL;// &lc;
Uart2Handle = adl_OpenDevice ( DF_UART_CLID, &Settings );
if( Uart2Handle > OK )
debugmsg("+uart2:Port is now open\r\n");
uart2_itf = *pinterface2;
Fc.op = G_IOC_OP_SET;
Fc.type = UART_FC_RTS_CTS;
if ( uart2_itf.io_control ( Uart2Handle, IOC_UART_FC, ( void* ) &Fc ) )
debugmsg("red:+Error:uart2 IOC_UART_FC Failed\r\n");
//code taken from 4.1.4.2.1. and modified to fit
//switch to synchronous read
sUartEvent_t evt_setting;
//p_rx_buf = rx_buf;
//amount_tb_read = sizeof( rx_buf);
evt_setting.op = G_IOC_OP_SET;
evt_setting.valid_cb = (eUartEvId_t)(UART_CB_ON_RX_DATA_AVAILABLE |
UART_CB_ON_RX_DATA_AVAILABLE);
evt_setting.user_data = (void*)-1L; // not used
evt_setting.cb_list[5].evt_hdl = NULL;
evt_setting.cb_list[2].evt_hdl = (pGEvtNotif_t)&on_rxda_handler;
evt_setting.cb_list[2].user_data = (void*)-1L; // not used
if( uart2_itf.io_control( Uart2Handle, IOC_UART_EH, &evt_setting ) )
debugmsg("red:+Error:Failed to switch uart2 to synchronous read\r\n");
//send uart break
sUartSsIoc_t brk;
brk.op=G_IOC_OP_SET;
brk.sig_id=UART_SIG_BREAK;
brk.state=UART_SIG_BREAK;
if ( uart2_itf.io_control ( Uart2Handle, IOC_UART_SS , ( void* ) &brk ) )
debugmsg("red:+Error:uart2 break failed\r\n");
debugmsg("+uart2:Break Sent\r\n");
//send data byte
u8 bt[1];
bt[0]=0xC1;
uart2_itf.write(Uart2Handle,bt,1); //write a byte
else
debugmsg("red:+Error:Failed to open uart2\r\n");
Now basically, it claims the break is sent, but upon writing a byte to the port after sending the break, the device will freeze up and watchdog reset. If I disable the watchdog, it will freeze forever within the call to write.
I have already configured the port with the at+wmfm=0,0,2 command, as it did not want to open until I did this
What am I doing wrong, why does the uart break operation cause the module to lock up on further writes ?
Can anyone help ?
Steed.
