Semtech URC
Is there any detail docs of Semtech about list of all the URCs appear on semtech’s modules
Which module are you talking about?
EM? MC? RC? HL?
4G? 5G? Nbiot?
HL, I wonder if there is a list of URCs for modem’s responses
No, i don’t see such list
But you can search the keyword “urc” in AT command user guide
What is a urc? never heard of this before.
From the AT command user guide, it means "Unsolicited Result Codes "
Can I have a log on network connection on hl7810 or 7900 module please ?
Yes, you can use stt tool to capture network log
I mean can you provide me an example of network connection log on HL7900 or hl7810, the getting started document does not provide any detail log, just give a guide on how to connect
Do you have the altair tool to decode?
If no, then probably you cannot decode the log
no I don’t. Don’t you have any existing log files of the network connection process on the hl7900 or hl7810 ? Like a .txt file ?
What is the purpose of this???
Have you contacted distributor ?
I’m only doing research on the HL7900 modem. Since I don’t have the actual hardware, I’d like to ask if you could share any network‑connection log files from the HL modem — for example, a .txt log?”
I think you better contact distributor
I want to ask about the AT+CREG command, for I know CS(circuit switch) doesn’t exist on hl7900, only PS(packet switch) so why does response of CREG still +creg: 0,1 when hl7900 attached to network ?
normally you should use AT+CEREG instead of +CREG which is mainly for GSM.
Yes but I want to know why it still have +creg:0,1 when hl7900 doesn’t support GSM; Is Creg appeared to serve compatible purpose ?
maybe
but better use AT+CEREG command
Does hl7900 have any urc that its functionality like +QUSIM: 1 of Quectel ?
Do you mean the sim detect function by at+ksimdet?
