Hi All,
This one’s for the Legato gurus
Can you supply me with some instructions for using GDB from DS3 to the Legato please.
Got an application that’s segfaulting and I need to trap where the fault is happening.
ta, Dave
Hi All,
ta, Dave
Hi Dave,
here are some instructions to get GDB working with your Legato Linux app:
… and you should be done. Launch the debug session and enjoy!
Hi Daav.
Excellent, Thank You.
Now beaten into shape.
There are a couple of ‘gotchas’ in the debug process - the main one is that the scp process can’t build the path to put the debug executable. For example:
C/C++ application is Debug/Hello
Project is Hello
connection properties remote workspace location is /home/root
When you try to debug, the debug process tries to put the executable at /home/root/Hello/Debug - which doesn’t exist and the scp process can’t (or doesn’t) make the path - so the debug session startup fails. If you ssh into the legato and manually create the full path that the debugger needs (i.e. mkdir -p /home/root/Hello/Debug) then all is well and the debug session works.
I don’t know if this is a bug in your code or something in CDT/Eclipse - but it took me a little while to work out why the debug session was crashing…
ciao, Dave
Good to know.
For your information: actually the Remote C/C++ Application launch configurations are part of the standard CDT features.
So we just integrated it in DS3 as part of the “goodies”, useful when you need to handle standard C/C++ projects aiming to run on the Legato Linux distro.
Our effort is focused on developing features around the Legato Application Framework itself.
Hi Daav,
No problems. Although I guess you connect to a legato app using GDB in a similar fashion?
Anyway, it’s good that you’ve included this functionality into DS.
Ciao, Dave
Yes, once you have a Legato application project, you can use a Legato application debug configuration to handle the debug session, whatever if the application is sandboxed or not.
