RC7611-1 with EVK, antannas not working?
I’ve been trying for a few days to connect to a remote server using through TCP using an RC7611-1 module. Since i wasn’t able to achieve it on my PCB, i bought the official sierra EVK for RC76xx modules.
I tried the following manipulation with two different RC7611-1 modules, one of them being the one that was given with the EVK itself.
ati
Model: RC7611
Revision: SWI9X07H_00.08.20.00 d73df7 jenkins 2021/10/14 00:48:45
IMEI: 358026262056750
IMEI SV: 18
FSN: CV3095021716B1
+GCAP: +CGSM
at+cpin?
+CPIN: READY
at+cfun?
+CFUN: 1
at+cgdcont?
+CGDCONT: 1,"IP","mmsbouygtel.com","0.0.0.0",0,0,0,0
at+cgact?
+CGACT: 1,0
at+cgact=1,1
+CME ERROR: no network service
at+cgatt=1
at+csq
+csq: 99,99
at+creg?
+CREG: 0,0
at+cgreg?
+CGREG: 0,0
at+cereg?
+CEREG: 0,0
at!band?
Index, Name
00, All bands
at!selrat?
!SELRAT: 00, Automatic
at!gstatus?
!GSTATUS:
Current Time:  552              Temperature: 27
Modem Mitigate Level: 0         ModemProc Mitigate Level: 0
Reset Counter: 1                Mode:        ONLINE
System mode:   LTE              PS state:    Not attached
IMS reg state: UNKNOWN          IMS mode:    Not Support
IMS Srv State: UNKNOWN SMS,UNKNOWN VoIP
LTE band:      No band          LTE bw:      Unknown
LTE Rx chan:    ---             LTE Tx chan:  ---
LTE CA state:  ACTIVE                   LTE Scell band:No band
LTE Scell bw:Unknown            LTE Scell chan:   42762
EMM state:     Deregistered     No Cell
RRC state:     RRC Idle
PCC RxM RSSI:  0                RSRP (dBm):  0
PCC RxD RSSI:  0                RSRP (dBm):  0
SCC RxM RSSI:  0                RSRP (dBm):  0
SCC RxD RSSI:  0                RSRP (dBm):  0
Tx Power:      --               TAC:         0000 (0)
RSRQ (dB):     0                Cell ID:     820EB030 (-2112966608)
SINR (dB):     0
I was never able to have AT+CSQ return me something else than “99,99”.
However, i used the same EVK with an HL8548 module and everything was working fine (same EVK configuration, same SIM card, same antenna). I was even able to connect to the remote server through TCP using the HL8548.
Am i missing an obvious configuration step ?
Rc7611 is for US market
Now it is used in france network
Not sure if the band is supported
Thanks for the reply, it indeed looks like this might be the issue, after investigating the bands more. We’ll have to test with the appropriate modules to be certain.
see if you can use this variant
Yes we chosed this one too after your feedback, thanks for confirming it is the right choice.
I’ll mark this post as solved and reopen one later if i encounter more trouble.
Thanks again jyijyi.
