QMI SDK Band 66 bitmask value
Then I cannot reproduce your problem.
I used the same FW as yours:
owner@CNHKG-EX-001367:~/QMI/SLQS04.00.23.src/pkgs/qa$ sudo ./qatesthostx86_64 -p …/…/build/bin/hostx86_64/slqssdk -n t1404
[sudo] password for owner:
Using …/…/build/bin/hostx86_64/slqssdk
#devices: 1
deviceNode: /dev/qcqmi0
deviceKey: 00000000000000
Using SLQS SDK version: SLQS04.00.23
Invoking test: SLQSGetSysSelectionPrefExt
Test Case 19 / 19 : Valid Test Case - All parameters set
Return Code: 0 (0x0)
Return Reason: Success
System Selection Preferences
Emergency Mode: 0x0
Mode Preference: 0x3f
Band Preference: 0x100600000ec00000
CDMA PRL Preference : 0xffff
Roaming Preference : 0xff
LTE Band Preference : 0xa700ba0e19df
Network Selection Preference: 0x0
Service Domain Preference : 0x2
GSM - WCDMA Acquisition Order Preference : 0x0
acq order len : 0x5
acq order: 0x8
acq order: 0x5
acq order: 0x4
acq order: 0x1
acq order: 0x2
Disabled RAT Bitmask: 0x0000
LTE Band Preference Ext.:
bits_1_64: 0xa700ba0e19df
bits_65_128: 0x2
bits_129_192: 0x0
bits_193_256: 0x0
Completed t1404…
Test Completed ----------------------------------
at
at!band?
Index, Name, GW Band Mask L Band Mask 1 TDS Band Mask L Band Mask 2 L Band Mask 3 L Band Mask 4
00, All bands 100600000EC00000 0000A700BA0E19DF 0000000000000000 0000000000000002 0000000000000000 0000000000000000
at!band=?
Index, Name, GW Band Mask L Band Mask 1 L Band Mask 2 TDS Band Mask L Band Mask 3 L Band Mask 4
00, All bands 100600000EC00000 0000A700BA0E19DF 0000000000000002 0000000000000000 0000000000000000 0000000000000000
01, Europe 3G 0002000000400000 0000000000000000 0000000000000000 0000000000000000 0000000000000000 0000000000000000
02, North America 3G 0000000004800000 0000000000000000 0000000000000000 0000000000000000 0000000000000000 0000000000000000
06, Europe 0002000000400000 00000000000801C5 0000000000000000 0000000000000000 0000000000000000 0000000000000000
07, North America 0000000004800000 000001000200185A 0000000000000002 0000000000000000 0000000000000000 0000000000000000
08, WCDMA ALL 100600000EC00000 0000000000000000 0000000000000000 0000000000000000 0000000000000000 0000000000000000
09, LTE ALL 0000000000000000 0000A700BA0E19DF 0000000000000002 0000000000000000 0000000000000000 0000000000000000
        0000000000000002 - B66
                                               0000800000000000 - B48
                                               0000200000000000 - B46
                                               0000040000000000 - B43
                                               0000020000000000 - B42
                                               0000010000000000 - B41
                                               0000000080000000 - B32
                                               0000000020000000 - B30
                                               0000000010000000 - B29
                                               0000000008000000 - B28
                                               0000000002000000 - B26
                                               0000000000080000 - B20
                                               0000000000040000 - B19
                                               0000000000020000 - B18
                                               0000000000001000 - B13
                                               0000000000000800 - B12
                                               0000000000000100 - B9
                                               0000000000000080 - B8
                                               0000000000000040 - B7
                                               0000000000000010 - B5
                                               0000000000000008 - B4
                                               0000000000000004 - B3
                                               0000000000000002 - B2
                                               0000000000000001 - B1
                              1000000000000000 - B19 (850)
                              0004000000000000 - B9 (1700)
                              0002000000000000 - B8  (900)
                              0000000008000000 - B6  (800)
                              0000000004000000 - B5  (850)
                              0000000002000000 - B4 (1700)
                              0000000000800000 - B2 (1900)
                              0000000000400000 - B1 (2100)
ati3
Model: EM7565
Revision: SWI9X50C_01.11.00.00 5ba42f jenkins 2019/06/28 09:51:52
IMEI: 353533100134710
IMEI SV: 10
FSN: UF913580100215
+GCAP: +CGSM
