Hi all
I’ve recently embarked on upgrading our application from the old ELF toolchain (which still used GCC4.0.1) over to the newer EABI toolchain. However, our project is written in C++, and when attempting to compile I’m getting trouble with the linker complaining that libg can’t find certain C methods like _kill, _pid and _fstat. I’ve managed to reproduce the problem by porting the C hello_world program to C++.
Here is the ported code:
/* Hello_World.c - Copyright Sierra Wireless Inc. (c) 2010 */
/* LICENSE */
/* If no specific agreement has been signed, this Source Code is subject to the following license terms: */
/* http://www.sierrawireless.com/productsandservices/AirPrime/Sierra_Wireless_Software_Suite/License/Userlicense.aspx */
/* If you modify this file, you are subject to the contribution rules described into this license */
/* File : Hello_World.c */
/* Object : Customer application */
/* contents : Customer main procedures */
/* Include files */
extern "C"{
#include "wm_types.h"
#include "adl_str.h"
#include "adl_port.h"
#include "adl_traces.h"
#include "adl_AppliInit.h"
#include "adl_RspHandler.h"
#include "adl_TimerHandler.h"
#ifndef __GNU_GCC__
/* Macro : DECLARE_CALL_STACK */
/* Object : The GCC compiler and GNU Newlib (standard C library) */
/* implementation require more stack size than ARM compilers. If */
/* the GCC compiler is used, the Open AT® application has to be */
/* declared with greater stack sizes. */
/* Variable Name |IN |OUT|GLB| Utilization */
/* X | X | | | required stack size */
#define DECLARE_CALL_STACK(X) (X)
#else /* #ifndef __GNU_GCC__ */
#define DECLARE_CALL_STACK(X) (X*3)
#endif /* #ifndef __GNU_GCC__ */
extern "C"
// Application tasks prototypes
extern void main_task ( void );
// Application tasks declaration table
const adl_InitTasks_t adl_InitTasks [] =
{ main_task, DECLARE_CALL_STACK ( 1024 ), "main", 1 },
{ 0, 0, 0, 0 }
/* Function : HelloWorld_TimerHandler */
/* Object : Timer handler */
/* Variable Name |IN |OUT|GLB| Utilisation */
/* ID | | | | Timer ID */
/* Context | | | | Context */
void HelloWorld_TimerHandler ( u8 ID, void * Context )
/* Send a trace: Hello World */
TRACE (( 1, "Embedded : Hello World" ));
/* Send a response: Hello World */
adl_atSendResponse ( ADL_AT_UNS, "\r\nHello World from Open-AT\r\n" );
/* Function : main_task */
/* Object : Customer application initialisation */
adl_InitType_e adl_InitType = adl_InitGetType ();
TRACE (( 1, "Embedded : Appli Init" ));
/* Set 1s cyclic timer */
adl_tmrSubscribe ( true, 10, ADL_TMR_TYPE_100MS, HelloWorld_TimerHandler );
And these are the linker errors I get:
09:35:05 **** Rebuild of configuration [Target]_ARM_EABI_GCC_Debug for project eabi2 ****
Info: Internal Builder is used for build
"C:\\Program Files (x86)\\Sierra Wireless\\Developer Studio\\tools\\armeabigcc\\4.7.4\\bin\\arm-none-eabi-g++.exe" -D__OAT_API_VERSION__=637 -D__WIP_PLUGIN_VERSION__=543 -D__Security_PLUGIN_VERSION__=105 -D__DEBUG_APP__ -DDS_TARGET_BB0 -DDS_DEBUG -D__arm -D__GNU_GCC__ -D__irq= "-IC:\\Program Files (x86)\\Sierra Wireless\\Embedded Software\\com.wavecom.openat.ide.spm.lib.plugin.model.Security.1.5.0.201108111447_1.5.0.201108111447\\resources/Security/itf" "-IC:\\Program Files (x86)\\Sierra Wireless\\Embedded Software\\com.wavecom.openat.ide.spm.lib.os.model.6.37.0.201202060950_6.37.0.201202060950\\resources/ADL/itf" "-IC:\\Program Files (x86)\\Sierra Wireless\\Embedded Software\\com.wavecom.openat.ide.spm.lib.os.model.6.37.0.201202060950_6.37.0.201202060950\\resources/ADL/basic" "-IC:\\Program Files (x86)\\Sierra Wireless\\Embedded Software\\com.wavecom.openat.ide.spm.lib.plugin.model.WIP.5.43.3.201212250709_5.43.3.201212250709\\resources/WIP/itf" "-IC:\\workspace\\eabi2\\inc" -O0 -Os -g -ggdb3 -Wall -c -fshort-enums -fdollars-in-identifiers -fno-strict-aliasing -fno-common -fomit-frame-pointer -mthumb-interwork -mthumb -march=armv5te -mapcs -mno-apcs-stack-check -o "src\\hello_world.o" "..\\src\\hello_world.cpp"
..\src\hello_world.cpp: In function 'void HelloWorld_TimerHandler(u8, void*)':
..\src\hello_world.cpp:85:73: warning: deprecated conversion from string constant to 'ascii* {aka char*}' [-Wwrite-strings]
..\src\hello_world.cpp: In function 'void main_task()':
..\src\hello_world.cpp:100:17: warning: unused variable 'adl_InitType' [-Wunused-variable]
"C:\\Program Files (x86)\\Sierra Wireless\\Developer Studio\\tools\\armeabigcc\\4.7.4\\bin\\arm-none-eabi-gcc.exe" -D__OAT_API_VERSION__=637 -D__WIP_PLUGIN_VERSION__=543 -D__Security_PLUGIN_VERSION__=105 -D__DEBUG_APP__ -DDS_TARGET_BB0 -DDS_DEBUG -D__arm -D__GNU_GCC__ -D__irq= "-IC:\\Program Files (x86)\\Sierra Wireless\\Embedded Software\\com.wavecom.openat.ide.spm.lib.plugin.model.Security.1.5.0.201108111447_1.5.0.201108111447\\resources/Security/itf" "-IC:\\Program Files (x86)\\Sierra Wireless\\Embedded Software\\com.wavecom.openat.ide.spm.lib.os.model.6.37.0.201202060950_6.37.0.201202060950\\resources/ADL/itf" "-IC:\\Program Files (x86)\\Sierra Wireless\\Embedded Software\\com.wavecom.openat.ide.spm.lib.os.model.6.37.0.201202060950_6.37.0.201202060950\\resources/ADL/basic" "-IC:\\Program Files (x86)\\Sierra Wireless\\Embedded Software\\com.wavecom.openat.ide.spm.lib.plugin.model.WIP.5.43.3.201212250709_5.43.3.201212250709\\resources/WIP/itf" "-IC:\\workspace\\eabi2\\inc" -O0 -Os -ggdb3 -Wall -c -fshort-enums -fdollars-in-identifiers -fno-strict-aliasing -fno-common -fomit-frame-pointer -mthumb-interwork -mthumb -march=armv5te -msoft-float -mapcs -mno-apcs-stack-check -o "src\\generated.o" "..\\src\\generated.c"
"C:\\Program Files (x86)\\Sierra Wireless\\Developer Studio\\tools\\armeabigcc\\4.7.4\\bin\\arm-none-eabi-g++.exe" -Wl,--script,gcc.lkopt -Wl,-( "src\\hello_world.o" "src\\generated.o" -Os -O2 -fshort-enums -fdollars-in-identifiers -ggdb3 -u _siwiStubsImplementation -nostartfiles -fomit-frame-pointer -mthumb-interwork -mthumb -march=armv5te -msoft-float -mfpu=fpa -mapcs -mno-apcs-stack-check -Wl,-nmagic -Wl,-Map,eabi2.map -laeabi "-LC:\\Program Files (x86)\\Sierra Wireless\\Developer Studio\\configuration\\org.eclipse.osgi\\bundles\\60\\1\\.cp\\libs\\oat" "C:\\Program Files (x86)\\Sierra Wireless\\Embedded Software\\com.wavecom.openat.ide.spm.lib.plugin.model.Security.1.5.0.201108111447_1.5.0.201108111447\\resources\\Security\\RVDS_Jamming.lib" "C:\\Program Files (x86)\\Sierra Wireless\\Embedded Software\\com.wavecom.openat.ide.spm.lib.plugin.model.Security.1.5.0.201108111447_1.5.0.201108111447\\resources\\Security\\RVDS_wipssl.lib" "C:\\Program Files (x86)\\Sierra Wireless\\Embedded Software\\com.wavecom.openat.ide.spm.lib.os.model.6.37.0.201202060950_6.37.0.201202060950\\resources\\ADL\\RVDS_ADL.lib" "C:\\Program Files (x86)\\Sierra Wireless\\Embedded Software\\com.wavecom.openat.ide.spm.lib.plugin.model.WIP.5.43.3.201212250709_5.43.3.201212250709\\resources\\WIP\\RVDS_WIP.lib" "C:\\Program Files (x86)\\Sierra Wireless\\Embedded Software\\com.wavecom.openat.ide.spm.lib.plugin.model.WIP.5.43.3.201212250709_5.43.3.201212250709\\resources\\WIP\\RVDS_WIPSoftLib.lib" -Wl,-) -oeabi2.axf
c:/program files (x86)/sierra wireless/developer studio/tools/armeabigcc/4.7.4/bin/../lib/gcc/arm-none-eabi/4.7.4/../../../../arm-none-eabi/lib/thumb\libg.a(lib_a-abort.o): In function `abort':
abort.c:(.text.abort+0xa): undefined reference to `_exit'
c:/program files (x86)/sierra wireless/developer studio/tools/armeabigcc/4.7.4/bin/../lib/gcc/arm-none-eabi/4.7.4/../../../../arm-none-eabi/lib/thumb\libg.a(lib_a-signalr.o): In function `_kill_r':
signalr.c:(.text._kill_r+0xe): undefined reference to `_kill'
c:/program files (x86)/sierra wireless/developer studio/tools/armeabigcc/4.7.4/bin/../lib/gcc/arm-none-eabi/4.7.4/../../../../arm-none-eabi/lib/thumb\libg.a(lib_a-signalr.o): In function `_getpid_r':
signalr.c:(.text._getpid_r+0x2): undefined reference to `_getpid'
collect2.exe: error: ld returned 1 exit status
09:35:05 Build Finished (took 689ms)
As you might be able to pick up from the compiler flags, this is for the SL6087 with a 6.47 OS
Any help you could give in getting this to compile on 6.47 would be great. If there’s any more information you need just ask.
