I am trying to implement the PPPoS from picotcp on HL6.
I have code working perfectly on SL6087 that works like:
ATZ
ATE0
AT+CREG=1
AT+CGREG=1
AT+CGDCONT=1,“IP”,“internet.proximus.be”,
AT+CGATT=1
ATD99**1#
CONNECT 38400
PPP: Modem connected to peer.
Sending LCP CONF REQ
Received LCP CONF ACK
Optflags: 0182
Optflags: 0182
Received LCP CONF REQ
Setting AUTH to c023
Sending LCP CONF ACK
PPP: LCP up.
PAP: Sending authentication request.
PAP: Received Authentication OK!
PPP: Authenticated.
Sending IPCP CONF REQ, ipcp size = 34
Received IPCP CONF REQ
Sending IPCP CONF ACK
Received IPCP CONF REJ
Sending IPCP CONF REQ, ipcp size = 22
Received IPCP CONF NAK
Received IPCP CONF ACK
PPP: IPCP up.
Received IP config 46.179.146.96
Received DNS: 80.201.237.239
Assigned ipv4 46.179.146.96 to device ppp0
setsockopt: Nagle algorithm disabled.
Launching PicoTCP echo server
When I try the exact same code, with exactly the same SIM card, on HL6 the negotation never gets passed LCP. And I just get:
Received LCP CONF REJ
What might be different on HL6 so that this doesn’t work on the HL6 modules?
