Not stable Wi-Fi connection
When I starts MQTT connection with broker, the Wi-Fi connection down:
AT+KMQTTCNX=1
+KMQTT_IND: 1,6
=> After 5-8 seconds:
+SRWSTASTATUS: 0,200 => “STA lost N beacons continuously”
+KMQTT_IND: 1,5
+KMQTT_IND: 1,0
What I do wrong?
are you testing with latest FW?
AT+CGMR
BX310x.2.7.3
can you check whether issue is on FW 2.6.3 ?
https://source.sierrawireless.com/resources/airprime/software/bx310x-firmware/#sthash.nmsdH4TR.dpbs
With FW 2.6.3 Wi-Fi connection looks stable.
But now when I connect to MQTT broker I get connection error:
AT+KMQTTCNX=1
+KMQTT_IND: 1,0 => MQTT connection aborted error.
You can capture wireshark log on server side to see what is happening
FW 2.6.3 Wi-Fi connection not stable, but much better than FW 2.7.3.
Sometimes the Wi-Fi connection down (25%):
AT+KMQTTCNX=1
+KMQTT_IND: 1,0
and sometimes I get connection error (75%):
AT+KMQTTCNX=1
+KMQTT_IND: 1,0
ONLY with FM 2.5.0-2 Wi-Fi works perfect!
The question is what wrong in FM versions 2.6.3, 2.7.2 and 2.7.3?
can you use FW 2.5.0
NO, I can’t use FM 2.5.0, because FM 2.5.0-2 have ONLY 4 BT commands and zero BLE commands!!!
In AT Commands reference PDF file I see in BT commands section more than 30 commands available for FM 2.5.0+, BUT when I run AT+CALC command I see ONLY 4 BT commands:
AT+CLAC
+CLAC:
AT+SRBTADDR
AT+SRBTNAME
AT+SRBTPS
AT+SRBTSYSTEM
What’s going on?!?
