Trying to connect Airlink ES450 IPSec VPN to Synology NAS vpn. Any help is appreciated
Hi jfilley,
To configure IPSec VPN for ES450, In ACEmanager, go to VPN:
- Select VPN1 or 2/3/4/5
- In the VPN Type field, select IPsec Tunnel
- Set up Synology NAS Server IP in " VPN Gateway Address"
- Set pre-shared key: the same as key on server
- IKE encryption algorithm/ IKE authentication algorithm/ IKE key group : the same as configuration on server
- Local address and netmask: the subnet under ES450
- Remote address and netmask: the subnet at remote site
Once configuration is completed, Set VPN Policy button
For more details, you can find the user guide in this document https://source.sierrawireless.com/resources/airlink/software_reference_docs/airlink-aleos-configuration-guide-es450/#sthash.8fTRawAa.dpbs
