Hi
I’m sorry about this I’m fairly new to Lua
What is the format of the return value from readDiscreteInputs()?
local vals = mb:readDiscreteInputs(11,00,32)
printf("modbus value: %s ", vals)
Any hints on how to extract the bit data?
Thanks in advance
Ted
Hi Ted,
The value is most likely returned in a numeric format that you can manipulate to extract or examine individual bits.
Keep in mind that Lua provides variable “coercion”. In other words, because you are asking to print it as a string “%s” Lua simply does the conversion and prints the result in ASCII. I think if you perform bitwise or logical math on the same variable you will get the results you desire.
Tanda
Hi Tanda
Thanks you are correct = the following works:
local mb = modbus.new("/dev/ttyS0")
-- Read 32 modbus digital inputs
-- Print the values
if(vals) then
for offset = 1,(32/8) do
value = string.byte(vals,offset)
printf("modbus value: 0x%x", value)
end
else
print("No modbus device found")
end
Thank you both for your answer.
You may find the module ‘pack’ useful to manipulate binary data, especially when dealing with various element size and endianness coming from the device.
You can find the documentation of this module there : developer.sierrawireless.com/en/ … F_API.aspx
(The initial question of this threads indicates the modbus module doc has room for improvements, I’ve noted that point
