MC7710 with PID 9205, doesn't receive AT commands
Try reversing that. Your problem is that qmi_wwan binds to every interface which could possibly be RMNET/QMI. It doesn’t know which one is the correct one when you .use new_id. So it blocks qcserial from binding to interface #3, which is the AT command interface.
Once you have AT command access you should probably change to a supported PID, unless there is a specific reason this module is using 9205.
