I am trying to figure out how to send LWM2M data to airvantage. I use a WP8548 with FW
SWI9X15Y_07.04.01.01 r29947 CARMD-EV-FRMWR1 2015/10/01 17:45:03
Legato v 15.09.
The modem communicates with the server. After enabling it with AT+WDSC=3,1. And I can from the server side make sure that basic data is transmitted(Network tech, signal strenght, traffic etc). But I can get my custom data to the server. I have done the following.
Updated aded and cdef file with assets and the bindings.
CDEF
[code]sources:
AcalWs.c
requires:
api:
le_avdata.api
assets:
AcalAsset =
variables:
int gpio_select
int blinky_interval
}[/code]
ADEF
[code]version: 1.0.0
maxFileSystemBytes: 512K
executables:
AcalWs = ( AcalWsComponent )
processes:
envVars:
LE_LOG_LEVEL = DEBUG
run:
( AcalWs )
maxCoreDumpFileBytes: 512K
maxFileBytes: 512K
bindings:
AcalWs.AcalWsComponent.le_avdata -> avcService.le_avdata
[/code]
My code create the asset and try to send the data.
LE_INFO("Create asset");
asset = le_avdata_Create( "AcalAsset" );
LE_INFO("Register data callback");
gpio_select_event_handler = le_avdata_AddFieldEventHandler( asset, "gpio_select", gpio_select_event_handler_func, NULL);
LE_INFO("Send data to AirVantage");
le_avdata_SetInt( asset, "gpio_select", gpio );
le_avdata_SetInt( asset, "blinky_interval", blinky_interval );
On the server side I have created installed the application model
<?xml version="1.0" encoding="UTF-8"?>
<app:application xmlns:app="http://www.sierrawireless.com/airvantage/application/1.0" name="AcalWs" type="AcalWs" revision="1.0">
<application-manager use="LWM2M_SW"/>
<capabilities>
<communication use="legato"/>
<data>
<encoding type="LWM2M">
<asset default-label="AcalAsset" id="AcalAsset">
<variable default-label="gpio_select" path="0" type="int"/>
<variable default-label="blinky_interval" path="1" type="int"/>
</asset>
</encoding>
</data>
</capabilities>
<binaries>
<binary file="AcalWs.update"/>
</binaries>
</app:application>
The log looks like this
Oct 16 07:40:33 swi-mdm9x15 user.info Legato: INFO | AcalWs[7939]/AcalWsComponent T=main | AcalWs.c init_airvantage() 101 | Create asset
Oct 16 07:40:33 swi-mdm9x15 user.debug Legato: DBUG | AcalWs[7939]/<invalid> T=main | le_avdata_client.c le_avdata_Create() 628 | Sending message to server and waiting for response : 10 bytes sent
Oct 16 07:40:33 swi-mdm9x15 user.debug Legato: DBUG | avcDaemon[573]/<invalid> T=main | le_appInfo_client.c le_appInfo_GetName() 571 | Sending message to server and waiting for response : 8 bytes sent
Oct 16 07:40:33 swi-mdm9x15 user.info Legato: INFO | avcDaemon[573]/avcDaemon T=main | assetData.c assetData_CreateInstanceByName() 1835 | Creating asset instance for AcalWs/AcalAsset
Oct 16 07:40:33 swi-mdm9x15 user.debug Legato: DBUG | avcDaemon[573]/<invalid> T=main | le_cfg_client.c le_cfg_CreateReadTxn() 434 | Sending message to server and waiting for response : 20 bytes sent
Oct 16 07:40:33 swi-mdm9x15 user.debug Legato: DBUG | avcDaemon[573]/<invalid> T=main | le_cfg_client.c le_cfg_IsEmpty() 1473 | Sending message to server and waiting for response : 5 bytes sent
Oct 16 07:40:33 swi-mdm9x15 user.debug Legato: DBUG | avcDaemon[573]/<invalid> T=main | le_cfg_client.c le_cfg_GoToFirstChild() 817 | Sending message to server and waiting for response : 4 bytes sent
Oct 16 07:40:33 swi-mdm9x15 user.debug Legato: DBUG | avcDaemon[573]/<invalid> T=main | le_cfg_client.c le_cfg_GetNodeName() 1138 | Sending message to server and waiting for response : 9 bytes sent
Oct 16 07:40:33 swi-mdm9x15 user.debug Legato: DBUG | avcDaemon[573]/avcDaemon T=main | assetData.c CreateAssetDataFromModelByName() 931 | assetId=0
Oct 16 07:40:33 swi-mdm9x15 user.debug Legato: DBUG | avcDaemon[573]/<invalid> T=main | le_cfg_client.c le_cfg_GetString() 1697 | Sending message to server and waiting for response : 14 bytes sent
Oct 16 07:40:33 swi-mdm9x15 user.debug Legato: DBUG | avcDaemon[573]/avcDaemon T=main | assetData.c CreateAssetDataFromModelByName() 935 | strBuf=Application Object
Oct 16 07:40:33 swi-mdm9x15 user.debug Legato: DBUG | avcDaemon[573]/avcDaemon T=main | assetData.c CreateAssetDataFromModelByName() 936 | assetNamePtr=AcalAsset
Oct 16 07:40:33 swi-mdm9x15 user.debug Legato: DBUG | avcDaemon[573]/<invalid> T=main | le_cfg_client.c le_cfg_GoToNextSibling() 893 | Sending message to server and waiting for response : 4 bytes sent
Oct 16 07:40:33 swi-mdm9x15 user.debug Legato: DBUG | avcDaemon[573]/avcDaemon T=main | assetData.c CreateAssetDataFromModelByName() 931 | assetId=1
Oct 16 07:40:33 swi-mdm9x15 user.debug Legato: DBUG | avcDaemon[573]/avcDaemon T=main | assetData.c CreateAssetDataFromModelByName() 935 | strBuf=Process Object
Oct 16 07:40:33 swi-mdm9x15 user.debug Legato: DBUG | avcDaemon[573]/avcDaemon T=main | assetData.c CreateAssetDataFromModelByName() 931 | assetId=1000
Oct 16 07:40:33 swi-mdm9x15 user.debug Legato: DBUG | avcDaemon[573]/avcDaemon T=main | assetData.c CreateAssetDataFromModelByName() 935 | strBuf=AcalAsset
Oct 16 07:40:33 swi-mdm9x15 user.debug Legato: DBUG | avcDaemon[573]/<invalid> T=main | le_cfg_client.c le_cfg_CancelTxn() 624 | Sending message to server and waiting for response : 4 bytes sent
Oct 16 07:40:33 swi-mdm9x15 user.info Legato: INFO | avcDaemon[573]/avcDaemon T=main | assetData.c assetData_CreateInstanceById() 1710 | Creating asset instance for AcalWs/1000
Oct 16 07:40:33 swi-mdm9x15 user.debug Legato: DBUG | avcDaemon[573]/<invalid> T=main | le_cfg_client.c le_cfg_CreateReadTxn() 434 | Sending message to server and waiting for response : 25 bytes sent
Oct 16 07:40:33 swi-mdm9x15 user.debug Legato: DBUG | avcDaemon[573]/<invalid> T=main | le_cfg_client.c le_cfg_GoToNode() 689 | Sending message to server and waiting for response : 11 bytes sent
Oct 16 07:40:33 swi-mdm9x15 user.debug Legato: DBUG | avcDaemon[573]/<invalid> T=main | le_cfg_client.c le_cfg_GetString() 1697 | Sending message to server and waiting for response : 18 bytes sent
Oct 16 07:40:33 swi-mdm9x15 user.debug Legato: DBUG | avcDaemon[573]/<invalid> T=main | le_cfg_client.c le_cfg_GetString() 1697 | Sending message to server and waiting for response : 16 bytes sent
Oct 16 07:40:33 swi-mdm9x15 user.debug Legato: DBUG | avcDaemon[573]/<invalid> T=main | le_cfg_client.c le_cfg_GetNodeType() 1061 | Sending message to server and waiting for response : 12 bytes sent
Oct 16 07:40:33 swi-mdm9x15 user.debug Legato: DBUG | avcDaemon[573]/avcDaemon T=main | assetData.c CreateFieldFromModel() 487 | No default for name=gpio_select
Oct 16 07:40:33 swi-mdm9x15 user.debug Legato: DBUG | avcDaemon[573]/avcDaemon T=main | assetData.c CreateFieldFromModel() 487 | No default for name=blinky_interval
Oct 16 07:40:33 swi-mdm9x15 user.info Legato: INFO | avcDaemon[573]/avcDaemon T=main | lwm2m.c AssetActionHandler() 379 | /AcalWs/1000/0 created.
Oct 16 07:40:33 swi-mdm9x15 user.info Legato: INFO | avcDaemon[573]/avcDaemon T=main | assetData.c assetData_CreateInstanceById() 1806 | Finished creating instance 0 for AcalWs/1000
Oct 16 07:40:33 swi-mdm9x15 user.debug Legato: DBUG | avcDaemon[573]/avcDaemon T=main | avData.c le_avdata_Create() 332 | instanceId=0
Oct 16 07:40:33 swi-mdm9x15 user.debug Legato: DBUG | avcDaemon[573]/<invalid> T=main | le_avdata_server.c Handle_le_avdata_Create() 557 | Sending response to client session 0x26674 : 4 bytes sent
Oct 16 07:40:40 swi-mdm9x15 user.warn Legato: -WRN- | appCtrl[8269]/framework T=unknown | mem.c InitPool() 276 | Memory pool name 'framework.hashMap_refPathIteratorMap' is truncated to 'framework.hashMap_refPathIterat'
Oct 16 07:40:40 swi-mdm9x15 user.warn Legato: -WRN- | appCtrl[8269]/framework T=main | mem.c InitPool() 276 | Memory pool name 'framework.hashMap_refEventHandlers' is truncated to 'framework.hashMap_refEventHandl'
Oct 16 07:40:40 swi-mdm9x15 user.warn Legato: -WRN- | appCtrl[8269]/framework T=main | mem.c InitPool() 276 | Memory pool name 'framework.hashMap_refHandlersRef' is truncated to 'framework.hashMap_refHandlersRe'
Oct 16 07:40:40 swi-mdm9x15 user.warn Legato: -WRN- | appCtrl[8269]/framework T=main | mem.c InitPool() 276 | Memory pool name 'framework.hashMap_MessagingServices' is truncated to 'framework.hashMap_MessagingServ'
Oct 16 07:40:40 swi-mdm9x15 user.warn Legato: -WRN- | appCtrl[8269]/framework T=main | mem.c InitPool() 276 | Memory pool name 'framework.msgs-LogControlProtocol' is truncated to 'framework.msgs-LogControlProtoc'
Oct 16 07:40:40 swi-mdm9x15 user.warn Legato: -WRN- | appCtrl[8269]/framework T=main | mem.c InitPool() 276 | Memory pool name 'framework.hashMap_refle_cfg_ClientHandler' is truncated to 'framework.hashMap_refle_cfg_Cli'
Oct 16 07:40:40 swi-mdm9x15 user.warn Legato: -WRN- | appCtrl[8269]/framework T=main | mem.c InitPool() 276 | Memory pool name 'framework.msgs-9dc5b2438c9592bf35478c68b2' is truncated to 'framework.msgs-9dc5b2438c9592bf'
Oct 16 07:40:40 swi-mdm9x15 user.warn Legato: -WRN- | appCtrl[8269]/framework T=main | mem.c InitPool() 276 | Memory pool name 'framework.hashMap_refle_appInfo_ClientHan' is truncated to 'framework.hashMap_refle_appInfo'
Oct 16 07:40:40 swi-mdm9x15 user.warn Legato: -WRN- | appCtrl[8269]/framework T=main | mem.c InitPool() 276 | Memory pool name 'framework.msgs-2208f55cb1d01d5f75b2e75500' is truncated to 'framework.msgs-2208f55cb1d01d5f'
Oct 16 07:40:40 swi-mdm9x15 user.err Legato: =ERR= | appCtrl[8269]/framework T=main | cgroups.c OpenCgrpFile() 167 | Could not open file '/sys/fs/cgroup/freezer/smsInboxService/tasks'. No such file or directory.
Oct 16 07:40:40 swi-mdm9x15 user.err Legato: =ERR= | appCtrl[8269]/framework T=main | cgroups.c OpenCgrpFile() 167 | Could not open file '/sys/fs/cgroup/freezer/voiceCallService/tasks'. No such file or directory.
Oct 16 07:40:43 swi-mdm9x15 user.info Legato: INFO | AcalWs[7939]/AcalWsComponent T=main | AcalWs.c init_airvantage() 108 | Send data to AirVantage
Oct 16 07:40:43 swi-mdm9x15 user.debug Legato: DBUG | AcalWs[7939]/<invalid> T=main | le_avdata_client.c le_avdata_SetInt() 811 | Sending message to server and waiting for response : 20 bytes sent
Oct 16 07:40:43 swi-mdm9x15 user.debug Legato: DBUG | avcDaemon[573]/<invalid> T=main | le_avdata_server.c Handle_le_avdata_SetInt() 683 | Sending response to client session 0x26674 : 0 bytes sent
Oct 16 07:40:48 swi-mdm9x15 user.info Legato: INFO | avcDaemon[573]/avcDaemon T=main | lwm2m.c RegUpdateTimerHandler() 342 | RegUpdate timer expired; reporting REG_UPDATE
Oct 16 07:40:48 swi-mdm9x15 user.debug Legato: DBUG | avcDaemon[573]/avcDaemon T=main | assetData.c assetData_GetAssetList() 3747 | tempStr=</legato/0/0>,
Oct 16 07:40:48 swi-mdm9x15 user.debug Legato: DBUG | avcDaemon[573]/avcDaemon T=main | assetData.c assetData_GetAssetList() 3723 | tempStr=</le_avsysinfo/1>,
Oct 16 07:40:48 swi-mdm9x15 user.debug Legato: DBUG | avcDaemon[573]/avcDaemon T=main | assetData.c assetData_GetAssetList() 3747 | tempStr=</lwm2m/9/0>,
Oct 16 07:40:48 swi-mdm9x15 user.debug Legato: DBUG | avcDaemon[573]/avcDaemon T=main | assetData.c assetData_GetAssetList() 3747 | tempStr=</lwm2m/9/1>,
Oct 16 07:40:48 swi-mdm9x15 user.debug Legato: DBUG | avcDaemon[573]/avcDaemon T=main | assetData.c assetData_GetAssetList() 3747 | tempStr=</le_iotBoard/0/0>,
Oct 16 07:40:48 swi-mdm9x15 user.debug Legato: DBUG | avcDaemon[573]/avcDaemon T=main | assetData.c assetData_GetAssetList() 3723 | tempStr=</le_lwm2mControl/0>,
Oct 16 07:40:48 swi-mdm9x15 user.debug Legato: DBUG | avcDaemon[573]/avcDaemon T=main | assetData.c assetData_GetAssetList() 3747 | tempStr=</le_AcalWs/1000/0>,
Oct 16 07:40:48 swi-mdm9x15 user.debug Legato: DBUG | avcDaemon[573]/avcDaemon T=main | assetData.c assetData_GetAssetList() 3747 | tempStr=</le_iotBoard/1/0>,
Oct 16 07:40:48 swi-mdm9x15 user.debug Legato: DBUG | avcDaemon[573]/avcDaemon T=main | assetData.c assetData_GetAssetList() 3723 | tempStr=</le_avsysinfo/0>,
Oct 16 07:40:48 swi-mdm9x15 user.debug Legato: DBUG | avcDaemon[573]/avcDaemon T=main | assetData.c assetData_GetAssetList() 3747 | tempStr=</le_AcalWs/1/0>,
Oct 16 07:40:48 swi-mdm9x15 user.debug Legato: DBUG | avcDaemon[573]/avcDaemon T=main | assetData.c assetData_GetAssetList() 3747 | tempStr=</le_AcalWs/0/0>,
Oct 16 07:40:48 swi-mdm9x15 user.debug Legato: DBUG | avcDaemon[573]/avcDaemon T=main | assetData.c assetData_GetAssetList() 3723 | tempStr=</le_lwm2mControl/1>,
Oct 16 07:40:48 swi-mdm9x15 user.debug Legato: DBUG | AcalWs[7939]/<invalid> T=main | le_avdata_client.c le_avdata_SetInt() 811 | Sending message to server and waiting for response : 24 bytes sent
Oct 16 07:40:48 swi-mdm9x15 user.debug Legato: DBUG | avcDaemon[573]/le_pa T=main | swiQmi.c swiQmi_OEMCheckResponseCode() 722 | QMI_LWM2M_REG_UPDATE_REQ_V01 sent to Modem
Oct 16 07:40:48 swi-mdm9x15 user.debug Legato: DBUG | avcDaemon[573]/<invalid> T=main | le_avdata_server.c Handle_le_avdata_SetInt() 683 | Sending response to client session 0x26674 : 0 bytes sent
But non of my own data received in the server. If I look in the timeline everytime minute the device connects to the server but there is no data.
Can anyone give me some advise?
