For Legato 15.10 the file
Was available to install cross-toolchain on Linux hosts like this
Will something similar be available for Legato 16.01? or is is already out there but I don’t know how to find it?
John
John
Hi John,
pre-built packages (including toolchain) will be available very soon (today) for install and usage from the command line.
Will keep you updated ASAP.
Hi John,
everything is now online.
Please refer to this post
Thanks daav
I notice that the Linux toolchain link
source.sierrawireless.com/resour … hain64bit/
Gets file
poky-swi-ext-glibc-x86_64-meta-toolchain-swi-ext-armv7a-vfp-neon-toolchain-swi-ext-1.7.2.sh
It’s a 149.7MB file
I downloaded in a similar way on the 12 Jan 2016 a file with the same name
It’s a 119.2MB file
Does the new file (with the same name) support both 16.01 and 15.10?
Maybe different names perhaps with a timestamp should be used?
Cheers
John
this Legato download page may not be maintained in the future.
The preferred way is to use the legato-spm tool, which allows you to install a complete development kit for Legato apps, including the toolchain.
And it’s managing versions numbers.
And you can have several toolchains installed at the same time (they’re not installed in the same directory).
Please just give a try
Hi Daav
Some reasons for using the original tool.
Is it possible to command line install with the legato-spm method which doesn’t need java?
Is the file here
Suitable to use with 16-01?
I am trying the legato-spm command line as well
Cheers
John
Yes it will be suitable.
Please can you share your experience on what kind of support issues can be given by Java?
Once the things installed with legato-spm, you should get a development experience quite similar to the one you’re familiar with.
Hi Daav
I’ve decided to test the legato-spm install on:
The install fails at
http://source.sierrawireless.com/resources/airprime/software/legato_application_development_kit_linux/
legato-spm --install --module WP85XX --update-link
.log contains (I’ve no idea how to debug this)
!SESSION 2016-02-26 15:57:04.341 -----------------------------------------------
eclipse.buildId=unknown
java.version=1.8.0_45-internal
java.vendor=Oracle Corporation
BootLoader constants: OS=linux, ARCH=x86_64, WS=gtk, NL=en_GB
Framework arguments: --install --module WP85XX --update-link
Command-line arguments: --install --module WP85XX --update-link
!ENTRY org.eclipse.osgi 4 0 2016-02-26 15:57:05.969
!MESSAGE Application error
!STACK 1
java.lang.NullPointerException: null values not allowed
at org.eclipse.core.internal.registry.ReferenceMap.put(ReferenceMap.java:351)
at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.getBundle(RegistryStrategyOSGI.java:151)
at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.createExecutableExtension(RegistryStrategyOSGI.java:166)
at org.eclipse.core.internal.registry.ExtensionRegistry.createExecutableExtension(ExtensionRegistry.java:905)
at org.eclipse.core.internal.registry.ConfigurationElement.createExecutableExtension(ConfigurationElement.java:243)
at org.eclipse.core.internal.registry.ConfigurationElementHandle.createExecutableExtension(ConfigurationElementHandle.java:55)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:191)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:134)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:104)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:380)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:235)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.lang.reflect.Method.invoke(Method.java:497)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:669)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:608)
at org.eclipse.equinox.launcher.Main.run(Main.java:1515)
at org.eclipse.equinox.launcher.Main.main(Main.java:1488)
By the way the pure linux command line install worked and functions fine
I also have the previous Dev Studio IDE installed and running fine in a clone copy of this VM / ubuntu
Cheers
John
Hi John,
Thanks for reporting, we’re reproducing it here. It looks to be some special handling of default configuration files handling when some core Eclipse bundles are installed as root user.
We’re working on a fix.
If you want to go further, you can clean your $HOME/.eclipse folder, this will workaround the issue.
Except this unexpected hassle, I hope you finally agree that installing legato-spm itself is not that terrible
Just FYI, we have a fix.
We pushed a fixed version of legato-spm, if you want to give a try.
(don’t forget the sudo apt-get update before installing, to refresh the packets database)
Hi daav
I tried the fix - no joy. Then I deleted ~/.eclipse folder. The legato-spm install then worked.
But - I looked at the Legato version files.
The legato-spm installs
/home/john/legato/packages/legato.framework.16.1.0.Beta/resources/legato/version
16.01.0.Beta
The no java command line installs
/home/john/legato-af/version
16.01.2
So it looks like the legato-spm version is older than the standard command line version???
Anyway to test the legato-spm install I copied the helloWorld example to another folder then
source ~/legato/packages/legato.sdk.latest/resources/configlegatoenv
make wp85
Built OK
The framework version running on WP85 latest release is Legato 16.01.0, indeed a bit older than what is published on github.
The pre-built packages aim to stick with the versions that are integrated in the official images.
I hit another linux legato-spm install issue - a different machine this time running Ubuntu 15-04 - it previously has had most of the Legato releases installed since this time last year.
~$ legato-spm --install --module WP85XX --update-link
An error has occurred. See the log file
1457694083779.log (15.5 KB)
A bit of guess work here but the problem was due to the wrong java version running - I had 8 installed but previous versions were also installed and one of them was being selected (I’ve no idea why)
Running
sudo update-alternatives --config java
Gave me this list
[code]There are 2 choices for the alternative java (providing /usr/bin/java).
0 /opt/java/64/jre1.7.0_55/bin/java 2000 auto mode
1 /opt/java/64/jre1.7.0_55/bin/java 2000 manual mode
Question is what does auto mode mean - and should (2) have status auto mode?
Anyway after switching from (0) to (2) the install worked
Cheers John
Hi John,
you were right, this was the way to fix it.
By the way, we’ll probably need to add a more friendly error message in such cases.
I guess that the auto mode just highlights what will be automatically selected when you do
sudo update-alternatives --auto java
