/ File : ping.h /
/ Object : Customer application header /
/ contents : ADL Ping GPRS Sample /
#ifndef ADL_EXAMPLE_PING_GPRS
#define ADL_EXAMPLE_PING_GPRS
#define htons(A) ((((A) & 0xFF00) >> 8) | (((A) & 0x00FF) << 8))
#define htonl(A) ((((A) & 0xFF000000) >> 24) | (((A) & 0x00FF0000) >> 8) | (((A) & 0x0000FF00) << 8) | (((A) & 0x000000FF) << 24))
#define TCP 0x06
#define UDP 0x11
#define ICMP 0x01
#define ECHO 8
#define ECHO_REPLY 0
#define TRACEROUTE 30
// Flash objects ID
typedef enum
PING_FLHID_APN,
PING_FLHID_LOGIN,
PING_FLHID_PASSWORD,
PING_FLHID_IP,
PING_FLHID_LAST
} ping_FlashIds_e;
typedef struct {
u8 Version_HLen;
u8 Service;
u16 TotalLength;
u16 ID;
u16 Frag;
u8 TTL;
u8 Protocol;
u16 Checksum;
u32 SourceAddress;
u32 DestAddress;
//u8 Payload [10];
} IPDatagram;
//u8 IPAddress [4];
typedef struct {
u8 Type;
u8 Code;
u16 Checksum;
u16 Identifier;
u16 SeqNumber;
u8 payload[2];
} ICMPDatagram;//8
typedef struct {
u16 src_portno; // Source port number
u16 dst_portno; // Destination port number
u16 udp_length; // UDP packet length
u16 udp_checksum; // UDP checksum (optional)
u8 payload[2];
} UDPDatagram;
/* prototypes */
// GPRS Command Handler
s8 GPRS_Handler(u16 Event,u8 Cid);
// FCM Comand Handler
/* FCM control events handler /
bool FCM_ControlHandler( u8 Event);
/ FCM data events handler */
bool FCM_DataHandler( u16 DataLen, u8 * Data);
// Ping Timer Handler
void Ping_TimerHandler ( u8 ID );
// Ping GPRS Start Up Command Handler
//void Cmd_PING_Handler(adl_atCmdPreParser_t *paras);
// Customer application initialisation
void adl_main ( adl_InitType_e InitType );
bool Wind4_Handler( adl_atUnsolicited_t * param );
void gprsTimer( u8 ID );
void Ping_UpdateGSETParameter ( u8 id, ascii ** ParamStr, bool bWrite );
u32 ConvertIP_atoi ( ascii * aIP );
ascii * ConvertIP_itoa ( u32 iIP, ascii * aIP );
u16 checksum(u16 *buffer, s32 size);
void Cmd_TCPIP_Handler(adl_atCmdPreParser_t *paras);
void invokeHandler(u8 ikey);
#endif
#include “adl_global.h”
#include “ping.h”
#define KEY_NONE 0xFF
/ Mandatory variables /
/ wm_apmCustomStack /
/ wm_apmCustomStackSize /
u32 wm_apmCustomStack [ 512 ];
const u16 wm_apmCustomStackSize = sizeof ( wm_apmCustomStack );
// Flash objects handle
static const ascii * PING_FLH_HANDLE = “WmPING”;
static const u8 PACKETSIZE = 30;
// Parameters of the GPRS account
adl_gprsSetupParams_t SetupParams;
adl_gprsInfosCid_t InfosCid;
s8 FCM_Handler = 0;
s8 fcmReady = 0;
static u32 HostAddr; //IP Host Addr from the PING response
static u8 Ping_Send, Ping_Rec, ping_Time = 10;
static u16 ping_PacketSize = 30, ping_LastPacketSize;
static adl_tmr_t* Ping_Timer;
static s32 ping_RequestMode;
static u32 ping_TotalSize = 400, ping_NbPackets;
u16 scasyip_send_udp(u8 *buff, u32 host, u16 hostport, u32 LocalAddr, u16 localport, u8 *msg){
u16 size, udpsize;
int iUdpChecksumSize;
IPDatagram ipPackage;
UDPDatagram udpPackage;
u8 * ptr;
//fill ip package
ipPackage.Version_HLen = 0x45;
ipPackage.Service = 0;
ipPackage.TotalLength = htons(PACKETSIZE);
ipPackage.ID = 0;
ipPackage.Frag = 0;
ipPackage.TTL = 64;
ipPackage.Protocol = UDP;
ipPackage.Checksum = 0;
ipPackage.SourceAddress = htonl(LocalAddr);
ipPackage.DestAddress = htonl(host);
ipPackage.Checksum = checksum ((u16 *)(&ipPackage), sizeof(ipPackage) );
//fill udp datagram
udpPackage.dst_portno = htons(hostport);
udpPackage.src_portno = htons(localport);
udpsize = sizeof(udpPackage);
udpPackage.udp_length = htons(udpsize);
udpPackage.udp_checksum = 0;
udpPackage.payload[0] = 1;
udpPackage.payload[1] = 2;
//Calculates the pseudo-header checksum of a UDP packet
ptr = buff;
wm_memset(buff, 0, PACKETSIZE);
wm_memcpy(ptr, &ipPackage.SourceAddress, sizeof(ipPackage.SourceAddress));
ptr += sizeof(ipPackage.SourceAddress);
iUdpChecksumSize += sizeof(ipPackage.SourceAddress);
wm_memcpy(ptr, &ipPackage.DestAddress, sizeof(ipPackage.DestAddress));
ptr += sizeof(ipPackage.DestAddress);
iUdpChecksumSize += sizeof(ipPackage.DestAddress);
ptr++;
iUdpChecksumSize += 1;
wm_memcpy(ptr, &ipPackage.Protocol, sizeof(ipPackage.Protocol));
ptr += sizeof(ipPackage.Protocol);
iUdpChecksumSize += sizeof(ipPackage.Protocol);
wm_memcpy(ptr, &udpPackage.udp_length, sizeof(udpPackage.udp_length));
ptr += sizeof(udpPackage.udp_length);
iUdpChecksumSize += sizeof(udpPackage.udp_length);
wm_memcpy(ptr, &udpPackage, sizeof(udpPackage));
ptr += sizeof(udpPackage);
iUdpChecksumSize += sizeof(udpPackage);
udpPackage.udp_checksum = checksum( (u16 *)buff, iUdpChecksumSize);
//udpPackage.udp_checksum = checksum( (u16 *)(&udpPackage), sizeof(udpPackage) );
wm_memcpy(buff, &ipPackage, sizeof(ipPackage) );
wm_memcpy(buff + sizeof(ipPackage), &udpPackage, sizeof(udpPackage) );
size = sizeof(ipPackage) + sizeof(udpPackage);
return size;
void scasyip_send_ping (u8 * buff, u32 host, u32 LocalAddr, u16 * size, u16 PayloadLength ){
ICMPDatagram icmpPackage;
//fill ip package
ipPackage.ID = 0;
ipPackage.Frag = 0;
ipPackage.TTL = 64;
ipPackage.Protocol = ICMP;
//DUMP(1, &ipPackage, sizeof(ipPackage) );
//fill ICMP package
icmpPackage.Type = ECHO;
icmpPackage.Code = 0;
icmpPackage.Checksum = 0;
icmpPackage.Identifier = 0;
icmpPackage.SeqNumber = 0;
icmpPackage.payload[0] = 32;
icmpPackage.payload[1] = 33;
icmpPackage.Checksum = checksum ((u16 *)(&icmpPackage), sizeof(icmpPackage));
//DUMP(1, &icmpPackage, sizeof(icmpPackage) );
wm_memcpy(buff + sizeof(ipPackage), &icmpPackage, sizeof(icmpPackage) );
//DUMP(1, buff, PACKETSIZE);
*size = sizeof(ipPackage)+sizeof(icmpPackage);
//return buff;
u8 scasyip_check_ping(u8 * buf, u16 DataLen){
IPDatagram *iphdr = NULL;
ICMPDatagram *icmphdr = NULL;
u16 iphdrlen;
u32 tick;
static u32 icmpcount = 0;
DUMP(1, buf, DataLen );
iphdr = (IPDatagram *)buf;
// Number of 32-bit words * 4 = bytes
iphdrlen = (iphdr->Version_HLen & 0x0F) * 4;
icmphdr = (ICMPDatagram *)(buf + iphdrlen);
if (icmphdr->Type != ECHO_REPLY)
TRACE((1, "nonecho type %d recvd\n", icmphdr->Type));
//printf("%d bytes from %s:", bytes, inet_ntoa(from->sin_addr));
TRACE((1, " icmp_seq = %d. ", icmphdr->Type));
//icmpcount++;
return icmphdr->Type;
/* Send a Ping packet on GPRS FCM flow */
void SendPingPacket ( void )
u16 size, PayloadSize;// = ping_PacketSize - ip_get_header_size();
u8 * PacketToSend;
s32 sFcmReturn;
PacketToSend = (u8 *)adl_memGet(PACKETSIZE);
wm_memset(PacketToSend, 0, PACKETSIZE);
scasyip_send_ping (PacketToSend, HostAddr, InfosCid.LocalIP, &size, PayloadSize );
TRACE((1, "package size:%d", size));
DUMP ( 1, PacketToSend, size );
/* Send packet */
sFcmReturn = adl_fcmSendData ( FCM_Handler, PacketToSend, size );
if ( sFcmReturn < OK )
TRACE (( 1, "Problem to send the packet" ));
adl_atSendResponse ( ADL_AT_UNS, "\r\nCannot send the packet\r\n" );
else
if ( sFcmReturn == ADL_FCM_RET_OK_WAIT_RESUME )
// Wait for resume before going on...
TRACE( (1, "Wait for resume before going on...") );
else
/* Start Timer */
Ping_Timer = adl_tmrSubscribe ( FALSE, ping_Time, ADL_TMR_TYPE_100MS, Ping_TimerHandler );
// Release buffer
adl_memRelease ( PacketToSend );
void sendUdpPackage( void ){
u8 * PacketToSend;
s32 sFcmReturn;
ascii message[10];
wm_memset( PacketToSend, 0, PACKETSIZE );
size = scasyip_send_udp (PacketToSend, HostAddr, 2008, InfosCid.LocalIP, 57258, message );
/* Send packet */
//Ping_Send++;
TRACE (( 1, "Problem to send udp packet" ));
adl_atSendResponse ( ADL_AT_UNS, "\r\nCannot send udp packet\r\n" );
else
/* OK */
//ascii Rsp [ 40 ];
TRACE (( 1, "udp Sent"));
// Release buffer
/ Function : Ping_TimerHandler /
/ Object : Timer handler /
/ Variable Name |IN |OUT|GLB| Utilisation /
/ ID | | | | Timer ID /
ascii NewText [ 50 ];
TRACE (( 1, “Embedded : Send next packet” ));
fcmReady = 1;
Ping_Send++;
/ The End */
wm_sprintf ( NewText, “\r\nResult : Ping Sent %d , Resp Received %d\r\n”, Ping_Send, Ping_Rec );
adl_atSendResponse ( ADL_AT_UNS, NewText );
bool Wind4_Handler( adl_atUnsolicited_t *param ){
adl_atUnSoUnSubscribe("+WIND: 4", Wind4_Handler);
adl_tmrSubscribe( FALSE, 1, ADL_TMR_TYPE_100MS, gprsTimer );
return TRUE;
bool keyHandler(adl_atUnsolicited_t *param){
u8 ikey = KEY_NONE, ipressed = 0;
ascii lBuffer[ 3 ];
s8 returnCode;
if(param){
ikey = wm_atoi( wm_strGetParameterString(lBuffer, param->StrData, 1) );
ipressed = wm_atoi( wm_strGetParameterString(lBuffer, param->StrData, 2) );
TRACE((1, “key %d is %d”, ikey, ipressed));
//20 -map 21 -up 22 -ok 23 -down
if(ikey==20 && ipressed==1){//map
wm_sndTonePlay(WM_SND_DEST_BUZZER, 100, 10, 9);
//wm_sndDtmfPlay(WM_SND_DEST_BUZZER, ‘A’, 0, 10);
//wm_sndMelodyPlay(WM_SND_DEST_BUZZER, myMelody, 6, 0, 9);
wm_strcpy(SetupParams.APN, "CMNET");
returnCode = adl_gprsSetup ( 1, SetupParams );
TRACE (( 1, "GPRS Setup return : %d", returnCode ));
}else if(ikey==21 && ipressed==1 && fcmReady == 1){//up
//wm_sndToneStop(WM_SND_DEST_BUZZER);
//wm_sndDtmfStop(WM_SND_DEST_BUZZER);
fcmReady = 0;
SendPingPacket();
//stopGPS();
}else if(ikey==22 && ipressed==1){//ok
// Stop the application
Ping_Send = 0;
Ping_Rec = 0;
fcmReady = 0;
adl_gprsDeact ( 1 );
adl_fcmUnsubscribe(FCM_Handler);
}else if(ikey==23 && ipressed==1 && fcmReady == 1){//down
//udpTimer();
//sendUdpPackage();
sendUdpPackage();
return FALSE;
void invokeHandler(u8 ikey){
s8 returnCode;
if(ikey==0){//map
}else if(ikey==1 && fcmReady == 1){//up
fcmReady = 0;
SendPingPacket();
//stopGPS();
}else if(ikey==2){//ok
Ping_Send = 0;
Ping_Rec = 0;
fcmReady = 0;
}else if(ikey==3 && fcmReady == 1){//down
//udpTimer();
//sendUdpPackage();
sendUdpPackage();
/ Function : adl_main /
/ Object : Customer application initialisation /
/ InitType | | | | Application start mode reason /
TRACE (( 1, “Embedded : Ping Appli Init” ));
adl_atCmdCreate("at+cmer=,1",FALSE, (adl_atRspHandler_t) NULL, NULL);
adl_atUnSoSubscribe("+CKEV: ", keyHandler);
adl_atUnSoSubscribe("+WIND: 4", (adl_atUnSoHandler_t)Wind4_Handler);
adl_atCmdSubscribe("at+cmd", Cmd_TCPIP_Handler, ADL_CMD_TYPE_TEST
| ADL_CMD_TYPE_PARA
| ADL_CMD_TYPE_READ
| 0x0051 );
void gprsTimer(u8 ID){
if ( adl_gprsSubscribe ( GPRS_Handler ) == OK )
adl_atSendResponse ( ADL_AT_UNS, “\r\nPing Appli is started\r\n” );
TRACE (( 1, “Embedded : Ping Appli is started” ));
HostAddr = ConvertIP_atoi("221.218.192.133");
// Subscribe to the GPRS settings flash object
adl_flhSubscribe ( PING_FLH_HANDLE, PING_FLHID_LAST );
// Read settings from flash (if possible)
Ping_UpdateGSETParameter ( PING_FLHID_APN, &SetupParams.APN, FALSE );
Ping_UpdateGSETParameter ( PING_FLHID_LOGIN, &SetupParams.Login, FALSE );
Ping_UpdateGSETParameter ( PING_FLHID_PASSWORD, &SetupParams.Password, FALSE );
Ping_UpdateGSETParameter ( PING_FLHID_IP, &SetupParams.FixedIP, FALSE );
else
adl_atSendResponse ( ADL_AT_UNS, "\r\nPing Appli init error\r\n" );
TRACE (( 1, "Embedded : Ping Appli init error" ));
/ Function : PING_Handler /
/ Objet : GPRS Service Events Handler /
/ Return : sReturn to or not to forward the Event /
/ Event | | | | Event from GPRS Service /
s8 GPRS_Handler ( u16 Event,u8 Cid )
s8 sReturn;
ascii buf [ 200 ];
sReturn = ADL_GPRS_NO_FORWARD; // by default - no forward events to ext app
TRACE (( 1, "Embedded : Event receive %d", Event ));
switch ( Event )
case ADL_GPRS_EVENT_RING_GPRS :
TRACE (( 1, "ADL_GPRS_EVENT_RING_GPRS" ));
break;
case ADL_GPRS_EVENT_NW_CONTEXT_DEACT :
TRACE (( 1, "ADL_GPRS_EVENT_NW_CONTEXT_DEACT" ));
break;
case ADL_GPRS_EVENT_ME_CONTEXT_DEACT:
TRACE (( 1, "ADL_GPRS_EVENT_ME_CONTEXT_DEACT" ));
break;
case ADL_GPRS_EVENT_NW_DETACH :
TRACE (( 1, "ADL_GPRS_EVENT_NW_DETACH" ));
break;
case ADL_GPRS_EVENT_ME_DETACH :
TRACE (( 1, "ADL_GPRS_EVENT_ME_DETACH" ));
break;
case ADL_GPRS_EVENT_NW_CLASS_B :
TRACE (( 1, "ADL_GPRS_EVENT_NW_CLASS_B" ));
break;
case ADL_GPRS_EVENT_NW_CLASS_CG :
TRACE (( 1, "ADL_GPRS_EVENT_NW_CLASS_CG" ));
break;
case ADL_GPRS_EVENT_NW_CLASS_CC :
TRACE (( 1, "ADL_GPRS_EVENT_NW_CLASS_CC" ));
break;
case ADL_GPRS_EVENT_ME_CLASS_B :
TRACE (( 1, "ADL_GPRS_EVENT_ME_CLASS_B" ));
break;
case ADL_GPRS_EVENT_ME_CLASS_CG :
TRACE (( 1, "ADL_GPRS_EVENT_ME_CLASS_CG" ));
break;
case ADL_GPRS_EVENT_ME_CLASS_CC :
TRACE (( 1, "ADL_GPRS_EVENT_ME_CLASS_CC" ));
break;
case ADL_GPRS_EVENT_NO_CARRIER :
TRACE (( 1, "ADL_GPRS_EVENT_NO_CARRIER" ));
break;
case ADL_GPRS_EVENT_DEACTIVATE_OK :
TRACE (( 1, "ADL_GPRS_EVENT_DEACTIVATE_OK" ));
sReturn = ADL_GPRS_FORWARD;
break;
case ADL_GPRS_EVENT_DEACTIVATE_OK_FROM_EXT :
TRACE (( 1, "ADL_GPRS_EVENT_DEACTIVATE_OK_FROM_EXT" ));
break;
case ADL_GPRS_EVENT_ANSWER_OK :
TRACE (( 1, "ADL_GPRS_EVENT_ANSWER_OK" ));
break;
case ADL_GPRS_EVENT_ANSWER_OK_FROM_EXT :
TRACE (( 1, "ADL_GPRS_EVENT_ANSWER_OK_FROM_EXT" ));
break;
case ADL_GPRS_EVENT_ACTIVATE_OK :
ascii localIP[ 20 ], DNS1 [ 20 ], DNS2 [ 20 ], Gateway [ 20 ];
TRACE (( 1, "Embedded : PDP Ctxt %d Activation OK",Cid ));
adl_gprsGetCidInformations ( 1, &InfosCid );
TRACE (( 1, "Embedded : IPCP Information DNS1 %u, DNS2 %u, Gateway %u", InfosCid.DNS1, InfosCid.DNS2, InfosCid.Gateway ));
wm_sprintf ( buf, "\r\nIPCP Information :\r\nLocal IP %s\r\nDNS1 %s\r\nDNS2 %s\r\nGateway %s\r\n",
ConvertIP_itoa ( InfosCid.LocalIP, localIP ),
ConvertIP_itoa ( InfosCid.DNS1, DNS1 ),
ConvertIP_itoa ( InfosCid.DNS2, DNS2 ),
ConvertIP_itoa ( InfosCid.Gateway, Gateway ) );
adl_atSendResponse ( ADL_AT_UNS, buf );
/* Open FCM Flows */
FCM_Handler = adl_fcmSubscribe ( ADL_FCM_FLOW_GPRS,
FCM_ControlHandler,
FCM_DataHandler );
fcmReady = 1;
break;
case ADL_GPRS_EVENT_GPRS_DIAL_OK_FROM_EXT :
TRACE (( 1, "ADL_GPRS_EVENT_GPRS_DIAL_OK_FROM_EXT" ));
break;
case ADL_GPRS_EVENT_ACTIVATE_OK_FROM_EXT :
TRACE (( 1, "ADL_GPRS_EVENT_ACTIVATE_OK_FROM_EXT" ));
adl_atSendResponse ( ADL_AT_UNS, "\r\nADL_GPRS_EVENT_ACTIVATE_OK_FROM_EXT\r\n" );
break;
case ADL_GPRS_EVENT_HANGUP_OK_FROM_EXT :
TRACE (( 1, "ADL_GPRS_EVENT_HANGUP_OK_FROM_EXT" ));
break;
case ADL_GPRS_EVENT_DEACTIVATE_KO :
TRACE (( 1, "ADL_GPRS_EVENT_DEACTIVATE_KO" ));
break;
case ADL_GPRS_EVENT_DEACTIVATE_KO_FROM_EXT :
TRACE (( 1, "ADL_GPRS_EVENT_DEACTIVATE_KO_FROM_EXT" ));
break;
case ADL_GPRS_EVENT_ACTIVATE_KO_FROM_EXT :
TRACE (( 1, "ADL_GPRS_EVENT_ACTIVATE_KO_FROM_EXT" ));
break;
case ADL_GPRS_EVENT_ACTIVATE_KO :
TRACE (( 1, "ADL_GPRS_EVENT_ACTIVATE_KO" ));
break;
case ADL_GPRS_EVENT_ANSWER_OK_AUTO :
TRACE (( 1, "ADL_GPRS_EVENT_ANSWER_OK_AUTO" ));
break;
case ADL_GPRS_EVENT_SETUP_OK :
TRACE (( 1, "PDP Ctxt Cid %d Setup is OK",Cid));
/* Activate context */
adl_gprsAct ( 1 );
break;
case ADL_GPRS_EVENT_SETUP_KO :
TRACE (( 1, "ADL_GPRS_EVENT_SETUP_KO" ));
break;
case ADL_GPRS_EVENT_ME_ATTACH :
TRACE (( 1, "ADL_GPRS_EVENT_ME_ATTACH" ));
break;
case ADL_GPRS_EVENT_ME_UNREG :
TRACE (( 1, "ADL_GPRS_EVENT_ME_UNREG" ));
adl_atCmdCreate("AT+CGATT=1", FALSE, (adl_atRspHandler_t) NULL, NULL);
break;
case ADL_GPRS_EVENT_ME_UNREG_SEARCHING :
TRACE (( 1, "ADL_GPRS_EVENT_ME_UNREG_SEARCHING" ));
break;
default :
TRACE (( 1, "Embedded : GPRS_Handler Event not treated"));
break;
return sReturn;
/ Function : FCM_ControlHandler /
/ Objet : FCM Control Events Handler /
/ Return : return value is not relevant /
switch ( Event )
case ADL_FCM_RET_ERROR_GSM_GPRS_ALREADY_OPENNED :
TRACE (( 1, “Flow GSM already Opened”));
break;
case ADL_RET_ERR_PARAM :
TRACE (( 1, "Open Flow GPRS Parameters Error"));
break;
case ADL_RET_ERR_ALREADY_SUBSCRIBED :
TRACE (( 1, "Flow GPRS already subscribed"));
break;
case ADL_FCM_EVENT_FLOW_OPENNED :
TRACE (( 1, "ADL_FCM_EVENT_FLOW_OPENNED" ));
// Check the request mode
if ( ping_RequestMode == 1 )
/* Sending the First Ping */
SendPingPacket();
break;
case ADL_FCM_EVENT_FLOW_CLOSED :
TRACE (( 1, "ADL_FCM_EVENT_FLOW_CLOSED" ));
break;
case ADL_FCM_EVENT_RESUME :
TRACE (( 1, "ADL_FCM_EVENT_RESUME" ));
/* Start Timer */
break;
case ADL_FCM_EVENT_MEM_RELEASE :
TRACE (( 1, "ADL_FCM_EVENT_MEM_RELEASE" ));
break;
default :
TRACE (( 1, "Embedded : FCM_ControlHandler Event not processed" ));
break;
return TRUE;
/ Function : FCM_DataHandler /
/ Objet : FCM Data Events Handler /
/ Return : return TRUE to release the credit, or FALSE if the credit /
/ must not be released /
bool FCM_DataHandler ( u16 DataLen, u8 * Data )
u8 result;
TRACE (( 1, "\r\n<- Receive FCM Data Blocks \r\n"));
//DUMP ( 1, Data, DataLen );
//Check the Ping response
result = scasyip_check_ping ( Data, DataLen );
if ( result == 0 )
adl_atSendResponse ( ADL_AT_UNS,"\r\nPing Rsp OK\r\n");
else if ( result == 8 )
adl_atSendResponse ( ADL_AT_UNS,"\r\nPing Rsp KO : bad chksum\r\n");
else if ( result == 7 )
adl_atSendResponse ( ADL_AT_UNS,"\r\nEcho Reply OK\r\n");
// If we have really received an IP Packet
if ( result == 0 || result == 8 || result == 7 )
// Count one more received packet
Ping_Rec++;
return TRUE;
/* Convert an IP address from u32 to ascii * */
wm_sprintf ( aIP, “%d.%d.%d.%d”,
( iIP >> 24 ) & 0xFF,
( iIP >> 16 ) & 0xFF,
( iIP >> 8 ) & 0xFF,
iIP & 0xFF );
return aIP;
/* Convert an IP address from ascii * to u32 */
ascii pTmp[4];
u8 i,j,k;
u8 pDest[4];
u32 native;
/* Convert Ascii PDP addr to Integer PDP addr */
i=0;
j=0;
k=0;
/* Octet 1 a N of the IP address */
while(aIP[i] != 0)
while(aIP[i] != 0x2E && aIP[i] != 0)
pTmp[j] = aIP[i];
j++;
i++;
pTmp[j] = 0;
pDest[k]=(u8)wm_atoi((void*)pTmp);
k++;
if(aIP[i] == 0x2E)
i++;
j=0;
/* Convert into u32 */
native = 0;
native = pDest[0] << 24;
native |= pDest[1] << 16;
native |= pDest[2] << 8;
native |= pDest[3];
return native;
unsigned long cksum=0;
while (size > 1)
cksum += *buffer++;
size -= sizeof(u16);
if (size)
cksum += *(u8*)buffer;
cksum = (cksum >> 16) + (cksum & 0xffff);
cksum += (cksum >>16);
return (u16)(~cksum);
// GPRS parameters flash update
// Check for mode
if ( bWrite )
// Check for provided string
if ( *ParamStr != NULL )
// Directly Write parameter
adl_flhWrite ( PING_FLH_HANDLE, id, wm_strlen ( *ParamStr ) + 1, *ParamStr );
else
// Erase parameter (if any)
adl_flhErase ( PING_FLH_HANDLE, id );
else
// Read parameter
s32 Length = adl_flhExist ( PING_FLH_HANDLE, id );
// Check if the object exists
if ( Length >= 0 )
// Check if the provided string was allocated
// Release the previous string
adl_memRelease ( *ParamStr );
// Allocate memory for the parameter
*ParamStr = adl_memGet ( Length );
// Read from flash
adl_flhRead ( PING_FLH_HANDLE, id, Length, *ParamStr );
switch(paras->Type)
case ADL_CMD_TYPE_TEST:
break;
case ADL_CMD_TYPE_PARA:
{ u8 operation = ( u8 ) wm_atoi ( ADL_GET_PARAM ( paras, 0 ) );
invokeHandler(operation);
break;
