I am attempting to use the I2C (I squared C) bus to communicate with a slave device.
I am using the new IDE along with “Open AT OS Package (4.25.0.01), Library API: ADL” for “Open AT Firmware Package (6.6.3.g.00)”.
I am using the IO+USB+GPS IESM Plugin and the 16 pin IO plug to connect the modem to the slave device. From the various manuals I have determined the following:
- Pin 9 (Purple wire) of the socket is connected to GPIO 26 which is multiplexed with the clock line of the I2C bus.
- Pin 7 (White wire) of the socket is connected to GPIO 27 which is multiplexed with the signalling line of the I2C bus.
- Pin 16 (Black wire) of the socket is connected to modem ground (reference ground for the I2C bus)
The slave device is powered by an independant 5v power supply however the grounding can’t be managed well and as such the modem ground line is connected directly to the power supply ground to provide a common ground.
The slave device is operating on I2C slave address 0x30 and is expecting an intial read on boot.
I will not post the entire code here as most of it is unrelated but the relevant calls that I am using are as follows:
(note, the code below is a summary of the calls from a number of functions with constants replaced with their values to simplify the code down to its basics, please don’t comment on my use of magic numbers etc
//variables
adl_busSettings_u settings;
s32 success;
adl_busAccess_t accessMode =
0x00000000, //address
0, //Opcode
0, //Opcode Length
0, //Address length
ADL_BUS_SIZE_BYTE, //size
u8 readData[8];
//initialise settings
settings.I2C.ChipAddress = 0x30;
settings.I2C.Clk_Speed = ADL_BUS_I2C_CLK_STD;
//subscribe bus
iButton_busHdl = adl_busSubscribe(ADL_BUS_I2C, &settings);
//check bus subscribe result
if (iButton_busHdl < 0)
TRACE((1, "Subscribe failed"));
return FALSE;
TRACE((1, "Subscribe succeeded."));
//read status register
success = adl_busRead(iButton_busHdl, &accessMode, 1, readData);
//check read success
if (success == OK)
TRACE((1, "Read Good, read %d", readData[0]));
else
TRACE((1, "Read failed: %d", success));
The output from the above code is as follows (trace level, trace):
24, Bus subs (4): 0
1, Subscribe succeeded.
24, Bus Read (0,1): -21
1, Read failed: -21
I have looked up error value -21 and it is ADL_BUS_LINE_ERROR.
Unfortunately the only documentation I can find on it is from the ADL guide: “ADL_BUS_LINE_ERROR if I2C lines are not in a good state (I2C bus only).”
I didn’t find this particularly helpful.
If anyone can tell me what step I am missing or what I have done wrong it would be greatly appreciated since I’m completely stuck on this. Nothing I have tried has changed the outcome at all.
