How to use the ADC in Legato app?
Cross-post from the mangOH forum - as I think this is generic to Legato, and not specific to mangOH?
As described in the cross-post, I got it to build - but it doesn’t work.
:frowning:
le_adc_ReadValue() returns -6; which is LE_FAULT = “Unspecified internal error
Any ideas :question:
Awnell,
Please, upgrade your system with last version of legato (16.04.0) and use cm adc read EXT_ADC1 or 2. It work.
Best regards,
Sylvain
Thanks.
Can you confirm that what I’ve done is correct - so it’s just the update that I need?
How do I check the current Legato version on the target?
But that’s a command-line tool, isn’t it :question:
What I need is to read the ADC from within an application.
OK - I found it: legato.io/legato-docs/latest/too … egato.html
Yes, it is:
So if this command fails, I guess that explains why my app also failed?
Note that the documentation is incomplete: legato.io/legato-docs/latest/too … get_cm_adc - it refers to “the names returned” but doesn’t say how to get them returned!
after doing the update, the cm adc read command does now seem to work;
but the cm adc list is broken!
There doesn’t seem to be a package yet for Developer Studio - so my app refuses to start because its Legato version doesn’t match the version running on the target :exclamation:
:angry:
I had Developer Studio 4.0; it needs to be updated to 4.1 - then a Legato 16.4.0 Package becomes available to install …
By George - I do believe we’ve got it :exclamation:
:smiley:
So to get this working required:
  1. Firmware 16.04.0 - which was only released on 9 June;
  2. Developer Studio 4.1 - dated 8 June.
Does this mean that I’m the first (outside SiWi) to get this working?! :open_mouth:
I have faced this type of problem any body have solution ?
i think this problem is hardware side ?
