Hiya,
Mostly compiler errors, although there were a couple of program errors.
Compiler errors:
- I needed to predefine the main_task() function before declaring the adl_InitTasks table (undefined function error)
- You had declared (and used in the IRQ functions) the variable speaker_handle. However, in all the adl_audioXXX() setup functions in main you had used the undeclared variable audio_handle
Program errors:
- in the main_task() you had never called adl_audioSubscribe() to subscribe to the audio handle
- in the irq_lowlevel() you had never explicity set the static x variable to a value. I know the compiler is supposed to implicitly initialize static variables to zero - but you never know what’s going on under the hood!
It’s also a good idea to check the return values of subscriptions (irq, audio etc) for errors and let yourself know. I’ve put a few TRACE() macro calls in the code as well to output some info during the program run.
I agree with you, we need to hear from SiWi about this one…
I’ve attached my version (which has the same issue as you have!) below.
OK: I’ve inserted the code inline as the Forum is not letting me post attachments…
#include "adl_global.h"
void main_task( void );
/* Mandatory variables */
/* wm_apmCustomStackSize */
//const u16 wm_apmCustomStackSize = 1024;
const u32 adl_InitIRQLowLevelStackSize = 4096;
const u32 adl_InitIRQHighLevelStackSize = 4096;
/* Tasks declaration table */
* @brief Task Declaration Table
const adl_InitTasks_t adl_InitTasks [] =
{ main_task, 3*1024, "MAIN", 1 }, // Main task
{ NULL, 0, NULL, 0 }
#ifdef __DO_NOT_COMPILE__
#define DECLARE_CALL_STACK(X) (X)
const adl_InitTasks_t adl_InitTasks [] = {
{main_task, DECLARE_CALL_STACK(1024), "main", 2},
{0, 0, 0, 0} /* Mark end of list */
ADL_DECLARE_LOWIRQ_STACK(4096);
ADL_DECLARE_HIGHIRQ_STACK(4096);
#endif
const u8 audiostream[] = {
// 0x23, 0x21, 0x41, 0x4D, 0x52, 0x0A, // Header from AMR file
0x04, 0x33,
0x00, 0x4F, 0xF2, 0x3D, 0x08, 0x33, 0x99, 0xA0,
0x62, 0x2E, 0x0E, 0x04, 0x15, 0x98, 0xAF, 0xF2,
0x06, 0xE0, 0xA4, 0xDD, 0x9B, 0x2F, 0x88, 0x3E,
0x04, 0x92, 0xEA, 0x4B, 0xF0, 0x0B, 0xA5, 0x15,
0x0B, 0x27, 0x34, 0xDC, 0x1E, 0x04, 0x94, 0x84,
0xD3, 0xC0, 0x46, 0x5F, 0x45, 0x98, 0x2C, 0xF2,
0x69, 0xD6, 0x04, 0x70, 0xEA, 0x93, 0xC0, 0x18,
0x3A, 0x7B, 0x91, 0x5A, 0xB9, 0xEA, 0x44, 0x04,
0x36, 0x1E, 0xC7, 0xC0, 0x14, 0x26, 0xC9, 0x5A,
0x0F, 0x5F, 0x6A, 0xE8, 0x04, 0x92, 0x00, 0xB7,
0xB2, 0x20, 0x9B, 0x49, 0x1B, 0x68, 0x26, 0xED,
0xD2, 0x04, 0x23, 0x1E, 0x37, 0x71, 0x0B, 0x9B,
0x05, 0x21, 0xCA, 0x44, 0xAB, 0x62, 0x04, 0x23,
0x00, 0xF3, 0xD0, 0x06, 0x35, 0xB5, 0xAC, 0x5F,
0x07, 0x04, 0x5A, 0x04, 0xFD, 0xF3, 0xD0, 0xF6,
0xF7, 0x77, 0xDE, 0x78, 0xFC, 0xCD, 0xEE, 0x2E,
0x04, 0x29, 0x92, 0x27, 0x0F, 0x91, 0x91, 0xED,
0x17, 0x10, 0xD4, 0x0A, 0xE4, 0x04, 0x1F, 0xC6,
0x27, 0x08, 0xE8, 0x97, 0xB3, 0x8F, 0xC5, 0xB3,
0x46, 0x90, 0x04, 0x95, 0xE8, 0x1C, 0x3C, 0xF5,
0x6D, 0x33, 0xA1, 0xE9, 0x74, 0x0A, 0xF8, 0x04,
0x34, 0x4B, 0x39, 0x6E, 0xD2, 0xF7, 0xDC, 0xFA,
0x69, 0x01, 0xFF, 0x0A, 0x04, 0xA0, 0x2D, 0x32,
0x6E, 0xCD, 0xDB, 0xC8, 0x39, 0x59, 0xD2, 0x88,
0x4C, 0x04, 0xAD, 0xF1, 0x32, 0x2F, 0xEA, 0xD3,
0x4E, 0xD0, 0xE9, 0xA4, 0xC1, 0x14, 0x04, 0x42,
0xF3, 0x25, 0xAD, 0xE0, 0xE6, 0x97, 0xE0, 0x6E,
0x98, 0x3C, 0x32, 0x04, 0x47, 0x5F, 0x22, 0x9D,
0xF3, 0x9F, 0xAA, 0x25, 0x22, 0x61, 0x19, 0x04,
0x04, 0xB5, 0xF0, 0x23, 0xEE, 0xE3, 0x14, 0x4A,
0x5A, 0xA3, 0x02, 0xCA, 0xB0, 0x04, 0xB5, 0x17,
0x33, 0xC9, 0xD3, 0x67, 0x30, 0x15, 0x21, 0x12,
0x02, 0xD4, 0x04, 0x71, 0xD0, 0x40, 0x2D, 0xF4,
0xC6, 0xA4, 0x13, 0xB7, 0x39, 0xDE, 0xAC, 0x04,
0xB5, 0xCA, 0x23, 0xAF, 0xF7, 0x30, 0xE8, 0xE2,
0x8C, 0x57, 0x17, 0xDC, 0x04, 0x48, 0xC4, 0x2A,
0xFF, 0xB1, 0xC6, 0x73, 0x44, 0x50, 0x59, 0xAA,
0x04, 0x04, 0xB5, 0xCA, 0x33, 0xFE, 0x91, 0xD5,
0x82, 0x12, 0x20, 0x8E, 0xEA, 0x26, 0x04, 0xAB,
0xB1, 0x48, 0xFE, 0x80, 0x7F, 0x78, 0x93, 0x8E,
0x0F, 0x15, 0x94, 0x04, 0xD3, 0x10, 0x6A, 0x43,
0xCB, 0x41, 0x75, 0x02, 0x25, 0x32, 0x3D, 0x7C,
0x04, 0x3F, 0x45, 0x3B, 0xFB, 0xFB, 0x2E, 0xEA,
0x67, 0x8E, 0xB5, 0x59, 0x3A, 0x04, 0xED, 0x41,
0x80, 0x1F, 0xCF, 0x4B, 0x53, 0x89, 0x19, 0x43,
0x88, 0x40, 0x04, 0x57, 0xD7, 0xF3, 0x7F, 0xF8,
0x9A, 0x0F, 0x73, 0xA2, 0x62, 0x60, 0x0C, 0x04,
0x1D, 0x3C, 0xCC, 0xFC, 0xC8, 0x65, 0x8B, 0x4F,
0x59, 0xA5, 0x61, 0xBE, 0x04, 0xD4, 0x77, 0x40,
0x9F, 0xFB, 0xA3, 0x65, 0x4D, 0xF6, 0xEE, 0x4F,
0x1C, 0x04, 0xAE, 0xBA, 0x43, 0x0F, 0xE9, 0xEF,
0x97, 0xBD, 0x1A, 0x37, 0xA4, 0x78, 0x04, 0xB5,
0x60, 0x3E, 0xAE, 0xC0, 0xAF, 0x97, 0x32, 0xB9,
0xE0, 0x41, 0x7A, 0x04, 0xB5, 0x10, 0x3A, 0xAE,
0xE2, 0x9D, 0xD0, 0xD7, 0x83, 0x19, 0x8E, 0x40,
0x04, 0xB5, 0xF0, 0x3B, 0xAC, 0xAE, 0xDF, 0x78,
0x0C, 0x79, 0xE6, 0x5B, 0x62, 0x04, 0xE7, 0x33,
0x38, 0xAC, 0xB4, 0xBD, 0x97, 0xD2, 0xAC, 0x52,
0xA2, 0xA2, 0x04, 0xD9, 0x73, 0x36, 0xAD, 0xF1,
0x56, 0x98, 0xAC, 0x92, 0xA2, 0x46, 0x68, 0x04,
0x8E, 0xC6, 0x35, 0xAD, 0xE4, 0x9C, 0xE7, 0xB4,
0x58, 0x50, 0xF5, 0xA2, 0x04, 0xD9, 0x73, 0x36,
0xAE, 0xE2, 0x94, 0xE4, 0xEE, 0xB6, 0xC5, 0x58,
0x9C, 0x04, 0xD9, 0x42, 0x36, 0xAB, 0xE3, 0x94,
0x6A, 0xC2, 0xC8, 0x2B, 0x20, 0x9C, 0x04, 0xB5,
0xF0, 0x36, 0x5D, 0xED, 0xE2, 0x10, 0x3B, 0x28,
0x82, 0x04, 0xE2, 0x04, 0xB5, 0x34, 0x32, 0xDD,
0x92, 0xD4, 0x24, 0x9C, 0x25, 0x61, 0xF5, 0xB8,
0x04, 0xD9, 0x10, 0x43, 0xFD, 0x9D, 0x88, 0xD9,
0x87, 0x8F, 0x64, 0xAD, 0x9E, 0x04, 0x3C, 0xEB,
0xFC, 0x2F, 0x3E, 0xB4, 0x29, 0xC7, 0x2C, 0x1A,
0x78, 0x9E, 0x04, 0x68, 0xF3, 0x46, 0x4E, 0xF7,
0x14, 0x5C, 0x1A, 0x0E, 0xBF, 0xB1, 0x4E, 0x04,
0x55, 0x11, 0x9F, 0xCF, 0x82, 0x0E, 0xE5, 0x0A,
0x40, 0x16, 0x63, 0x26, 0x04, 0xD4, 0x1F, 0x38,
0xBF, 0xF5, 0xE2, 0x22, 0x42, 0xC2, 0x8F, 0xE0,
0x64, 0x04, 0x42, 0x1D, 0x2E, 0x6C, 0xBE, 0xE1,
0xD9, 0xCA, 0xCC, 0x0A, 0x47, 0xE4, 0x04, 0x95,
0xC1, 0x2E, 0x9F, 0xE3, 0xF3, 0x27, 0xDB, 0xDB,
0x9F, 0x51, 0xA4, 0x04, 0x54, 0x27, 0x32, 0xBD,
0xEE, 0x0A, 0xA8, 0x5C, 0x0C, 0x04, 0xEB, 0x50,
0x04, 0x1E, 0xC1, 0x29, 0xBF, 0xE0, 0xDB, 0xD6,
0xB3, 0xFC, 0x1C, 0xC1, 0x5A, 0x04, 0xD9, 0x28,
0x32, 0xFE, 0x35, 0x1B, 0xC0, 0xFB, 0xA4, 0x91,
0xC7, 0x98, 0x04, 0x1E, 0xC8, 0x30, 0xFF, 0xFF,
0xB7, 0x6E, 0x3C, 0xA1, 0xD6, 0x31, 0xAA, 0x04,
0xE7, 0x01, 0x36, 0xFD, 0x96, 0x90, 0x5D, 0x5B,
0xF3, 0xB0, 0x97, 0x8A, 0x04, 0x42, 0xDC, 0x48,
0x5F, 0xD5, 0xB7, 0x5A, 0xCD, 0x7D, 0x70, 0x43,
0x4E, 0x04, 0x42, 0xDC, 0x3F, 0xBE, 0xF8, 0xD0,
0xE8, 0x10, 0x27, 0x9E, 0xD2, 0x52, 0x04, 0x42,
0x0F, 0x46, 0xED, 0xF5, 0xC7, 0xB1, 0x85, 0xE4,
0x69, 0xB3, 0x68, 0x04, 0x8F, 0x61, 0x4E, 0xFF,
0xE5, 0x81, 0x61, 0xC8, 0x38, 0x13, 0x22, 0x42,
0x04, 0xD3, 0xFC, 0x5E, 0x7B, 0xFD, 0xAA, 0x7E,
0xBC, 0x86, 0x61, 0x1C, 0xFC, 0x04, 0x95, 0x63,
0x5F, 0xCB, 0x90, 0xDF, 0x34, 0x88, 0xB6, 0x24,
0xA6, 0x20, 0x04, 0xB5, 0xF9, 0x6B, 0xFD, 0x9C,
0x63, 0x46, 0x20, 0x3A, 0x41, 0x24, 0xAC, 0x04,
0xD4, 0xA7, 0x6F, 0xCF, 0x97, 0xDC, 0x71, 0xE1,
0xAB, 0xB1, 0x3A, 0x9C, 0x04, 0x95, 0x40, 0x77,
0xF8, 0x88, 0x22, 0xB3, 0x8F, 0x94, 0xA8, 0xC6,
0x04, 0x04, 0xAB, 0x38, 0x67, 0xF9, 0x3B, 0x86,
0x35, 0x90, 0xC8, 0x14, 0x9F, 0x60, 0x04, 0xB5,
0x9C, 0x6C, 0xE4, 0x7B, 0x4C, 0xD4, 0x7C, 0x2C,
0x8E, 0x0D, 0x50, 0x04, 0x95, 0x08, 0x6B, 0xC3,
0x16, 0xEA, 0x45, 0xBB, 0xC5, 0xCD, 0x71, 0x70,
0x04, 0x95, 0xFC, 0xF0, 0xF3, 0x0B, 0x3A, 0x74,
0x39, 0x6C, 0x64, 0x9D, 0xCC, 0x04, 0xE7, 0x26,
0xF3, 0x03, 0x0E, 0xF7, 0x3A, 0x25, 0xD1, 0x09,
0x2E, 0x54, 0x04, 0x36, 0x3C, 0x34, 0x35, 0xFF,
0xA0, 0xBA, 0xE1, 0x41, 0x7A, 0x4C, 0x14, 0x04,
0x3B, 0x42, 0x04, 0x2F, 0x8B, 0x63, 0x64, 0x0E,
0x8B, 0x36, 0xBB, 0x1A, 0x04, 0xD4, 0xEC, 0x40,
0xCF, 0xEA, 0x65, 0xAE, 0xB8, 0x44, 0xF4, 0x6B,
0xEE, 0x04, 0xD3, 0x1D, 0x6A, 0xDF, 0x93, 0x67,
0xAA, 0x8E, 0x60, 0xC8, 0x82, 0x00, 0x04, 0xD3,
0xC7, 0x6A, 0xAB, 0x9A, 0xFC, 0x53, 0x24, 0xE2,
0x86, 0x8A, 0x92, 0x04, 0xF3, 0xC7, 0x6E, 0x9B,
0xC3, 0xA7, 0x2A, 0xE7, 0xDC, 0x7B, 0x84, 0x4A,
0x04, 0xB5, 0xF1, 0x6E, 0xBB, 0x32, 0xFA, 0x24,
0xA0, 0xED, 0x41, 0x6A, 0x62, 0x04, 0xF3, 0x4B,
0x75, 0xBB, 0x9E, 0xC0, 0x69, 0x5B, 0x54, 0x80,
0x6F, 0x54, 0x04, 0xF3, 0x09, 0x77, 0xFC, 0x73,
0x1E, 0xBB, 0x11, 0x75, 0x31, 0xBC, 0xE8, 0x04,
0xF3, 0x37, 0x77, 0xF0, 0x0B, 0x07, 0x55, 0xD9,
0xF8, 0x09, 0x2E, 0x4E, 0x04, 0xFE, 0x3C, 0x3F,
0xBE, 0x0D, 0x2C, 0x33, 0x91, 0x87, 0x95, 0x14,
0x44, 0x04, 0x34, 0x56, 0xAE, 0xF0, 0x2D, 0x19,
0xE3, 0xAD, 0xFC, 0x75, 0x36, 0x4E, 0x04, 0xFF,
0x18, 0x93, 0xC0, 0x17, 0x13, 0xC5, 0x9A, 0xD1,
0x47, 0xE1, 0x1A, 0x04, 0x58, 0xEA, 0x8F, 0xF0,
0x07, 0x06, 0x85, 0xFF, 0xE1, 0x04, 0xD2, 0xD2,
00
size_t audiostream_len = sizeof(audiostream)/sizeof(audiostream[0]);
s32 audio_handle;
s32 bufsize;
void *streambuf;
s32 currentpos = 0;
bool
irq_lowlevel(adl_irqID_e Source, adl_irqNotificationLevel_e NotificationLevel, adl_irqEventData_t *Data)
TRACE (( 1, "irq_lowlevel"));
if (currentpos >= audiostream_len)
return TRUE; /* Notify high-level IRQ */
wm_memcpy(streambuf, (const u8 *)&audiostream[ currentpos ], bufsize);
currentpos += bufsize;
*( (adl_audioStream_t *)Data->SourceData)->BufferReady = TRUE;
return FALSE; /* Don't notify high level IRQ */
bool
irq_highlevel(adl_irqID_e Source, adl_irqNotificationLevel_e NotificationLevel, adl_irqEventData_t *Data)
TRACE(( 1, "irq_highlevel" ));
adl_audioStop(audio_handle);
return FALSE; /* Return value is ignored in high-level IRQ */
// Audio Event Handler
void AudioEventHandler( s32 Handle, adl_audioEvents_e Event )
TRACE (( 3, "AudioEventHandler: Event [%d]", Event ));
return;
// Task startup delay timer handler
void TaskStartupTimerHandler( u8 Id, void *Context)
s32 irq_handle;
s32 irq_high_handle;
s32 ret;
// create handle for all audio events
audio_handle = adl_audioSubscribe ( ADL_AUDIO_SPEAKER, AudioEventHandler, ADL_AUDIO_RESOURCE_OPTION_FORBID_PREEMPTION );
TRACE (( 2, "audio_handle: %d", audio_handle ));
// NOTE: handle negative values here - denote errors
irq_handle = adl_irqSubscribe(irq_lowlevel, ADL_IRQ_NOTIFY_LOW_LEVEL,
ADL_IRQ_PRIORITY_LOW_LEVEL, /* Priority level */
ADL_IRQ_OPTION_AUTO_READ); /* Required option */
TRACE (( 2, "irq_handle: %d", irq_handle ));
irq_high_handle = adl_irqSubscribe(irq_highlevel, ADL_IRQ_NOTIFY_HIGH_LEVEL,
ADL_IRQ_PRIORITY_HIGH_LEVEL, /* Priority level */
0); /* Options (ignored for low level IRQs) */
TRACE (( 2, "irq_high_handle: %d", irq_high_handle ));
adl_audioGetOption( audio_handle, ADL_AUDIO_AMR_BUFFER_SIZE, &bufsize);
TRACE (( 2, "audioGetOption: ADL_AUDIO_AMR_BUFFER_SIZE: [%d]", bufsize));
bufsize = audiostream_len;
TRACE (( 2, "bufsize: [%d]", bufsize));
// Set Mixed voice option
adl_audioSetOption (audio_handle, ADL_AUDIO_AMR_MIXED_VOICE, FALSE);
// Set Codec Rate
adl_audioSetOption (audio_handle, ADL_AUDIO_AMR_SPEECH_CODEC_RATE, ADL_AUDIO_AMR_RATE_4_75);
// Set Buffer Size
ret = adl_audioSetOption (audio_handle, ADL_AUDIO_AMR_BUFFER_SIZE, bufsize);
TRACE (( 2, "adl_audioSetOption:ADL_AUDIO_AMR_BUFFER_SIZE returns [%d]", ret ));
// Memory allocation
streambuf = adl_memGet(bufsize);
ret = adl_audioStreamPlay(audio_handle, ADL_AUDIO_AMR, irq_handle, irq_high_handle, streambuf);
TRACE (( 2, "audioStreamPlay: returns [%d]", ret ));
return;
void
main_task (void)
TRACE (( 1, "main_task: Start:" ));
// wait 5 seconds before starting rest of task (in case we need to issue AT+WOPEN=0 !!!!
adl_tmrSubscribe ( FALSE, 50, ADL_TMR_TYPE_100MS, TaskStartupTimerHandler );
ciao, Dave
