I want to use password based authentication instead of public key based auth. But I couldn’t find any dropbear config file on the device where I can set this. Can anyone please let me know if this is possible? I tried with “ssh -s” option but this didn’t work for me.
Thanks in advance
jyijyi
July 25, 2023, 8:09am
2
does this help to reset password?
Hi, When I access the console with WP76XX for the first time, the following is displayed. _ It is strongly recommended to setup credentials for remote login. Please select one of the following options: Setup ssh keys and disable...
Hello @jyijyi , How can I check the default dropbear settings?
jyijyi
July 25, 2023, 8:45am
4
how about this?
root@fx30:~# cat /etc/init.d/dropbear
#!/bin/sh
### BEGIN INIT INFO
# Provides: sshd
# Required-Start: $remote_fs $syslog $networking
# Required-Stop: $remote_fs $syslog
# Default-Start: 2 3 4 5
# Default-Stop: 1
# Short-Description: Dropbear Secure Shell server
### END INIT INFO
# Do not configure this file. Edit /etc/default/dropbear instead!
# Import run environment
source /etc/run.env
PATH=/usr/local/sbin:/usr/local/bin:/sbin:/bin:/usr/sbin:/usr/bin
DAEMON=/usr/sbin/dropbear
NAME=dropbear
DESC="Dropbear SSH server"
PIDFILE=/var/run/dropbear.pid
DROPBEAR_PORT=22
DROPBEAR_EXTRA_ARGS=
NO_START=0
KEYS_PATH="/etc/dropbear"
set -e
test ! -r /etc/default/dropbear || . /etc/default/dropbear
test "$NO_START" = "0" || exit 0
test -x "$DAEMON" || exit 0
test ! -h /var/service/dropbear || exit 0
DROPBEAR_RSAKEY_DEFAULT="${KEYS_PATH}/dropbear_rsa_host_key"
# Check if /etc overlay is mounted. If no, /etc is assumed R/O.
if ! is_etc_writable; then
if is_flash_mountpoint_writable; then
KEYS_PATH="${FLASH_MOUNTPOINT_RFS}/etc/dropbear"
else
KEYS_PATH="/tmp/rootfs/etc/dropbear"
fi
mkdir -p ${KEYS_PATH}
DROPBEAR_RSAKEY_DEFAULT=${KEYS_PATH}/dropbear_rsa_host_key
DROPBEAR_DSSKEY_DEFAULT=${KEYS_PATH}/dropbear_dss_host_key
fi
test -z "$DROPBEAR_BANNER" || \
DROPBEAR_EXTRA_ARGS="$DROPBEAR_EXTRA_ARGS -b $DROPBEAR_BANNER"
test -n "$DROPBEAR_RSAKEY" || \
DROPBEAR_RSAKEY=$DROPBEAR_RSAKEY_DEFAULT
gen_keys() {
if [ -f "$DROPBEAR_RSAKEY" -a ! -s "$DROPBEAR_RSAKEY" ]; then
rm $DROPBEAR_RSAKEY || true
fi
test -f $DROPBEAR_RSAKEY || dropbearkey -t rsa -f $DROPBEAR_RSAKEY $DROPBEAR_RSAKEY_ARGS
case "$1" in
start)
echo -n "Starting $DESC: "
gen_keys
start-stop-daemon -S -p $PIDFILE \
-x "$DAEMON" -- -r $DROPBEAR_RSAKEY \
-p "$DROPBEAR_PORT" $DROPBEAR_EXTRA_ARGS
echo "$NAME."
stop)
echo -n "Stopping $DESC: "
start-stop-daemon -K -x "$DAEMON" -p $PIDFILE
echo "$NAME."
restart|force-reload)
echo -n "Restarting $DESC: "
sleep 1
echo "$NAME."
N=/etc/init.d/$NAME
echo "Usage: $N {start|stop|restart|force-reload}" >&2
exit 1
esac
exit 0
root@fx30:~#
root@fx30:~#
root@fx30:~#
root@fx30:~#
root@fx30:~# cat /etc/default/dropbear
DROPBEAR_EXTRA_ARGS="-B"
