How to send a POST method
I have a site
in it by POST, must complete 2 fields
“Meas_Point” and “Date”
I do:
AT+WIPCREATE=5,1,“http://mysite.ru
+WIPREADY: 5, 1
at+WIPFILE=5,1,4,“http://mysite.ru
CONNECT
/***** here i send
Meas_Point=5&Date=2011-03-29 08:12:47
website message does not come
what am I doing wrong?
Hi
My application performs an HTTP post with the following WIPSoft AT commands:
// setup
AT+WIPCFG=1
AT+WIPBR=1,6
AT+WIPBR=2,6,11,"INTERNET"
AT+WIPBR=4,6,0
// create a client connection to the server. note the port number is 80 for http
AT+WIPCREATE=2,1,"xxx.xxx.xxx.xxx",80
// post the data
AT+WIPDATA=2,1,2
GET http://xxx.xxx.xxx.xxx/page_name.aspx?Data=data_formatted_as_a_string
// when the post is done, leave data mode and close the socket
+++AT+WIPCLOSE=2,1
Sorry, but I cannot include the responses to the commands above. (That system has gone live in the mean time, and I might get executed without trail if I start posting test data to it)
Hope this helps
No it doesn’t - it performs an HTTP GET :exclamation:
My bad.
The app uploads data to a server using HTTP GET. I was rather confused when the suppliers gave my this solution to upload my data, but it seemed to do the trick. The problem with this method is that I have to leave Data Mode after each GET; this becomes very time consuming and is not an option when you have dozens of records to upload.
To send HTTP POST request, one should use socket mode TCP Client “2” instead of HTTP Client “5”.
You have to play with the HTTP POST header, e.g.
POST /post.php HTTP/1.1
Host: yourdomain.com
Content-Type: application/x-www-form-urlencoded
Content-Length: 16
id=123&value=456
Instead, for HTTP GET, I think socket mode HTTP Client “5” is possible with better efficiency, you just concat the parameter in the request URL.
L
[SOLUTION] Forgive me for reviving such an old thread, but I have struggled with this for several hours now and couldn’t find any decent references for doing an HTTP POST without embedding the POST data in the URL.
Here is what I believe to be a better approach. There is no such example in any official documentation I could find, but it seems to work. I added the solution here for future reference, as this is the first relevant page I found during my own search.
  1. Start IP Stack
AT+WIPCFG=1
  1. Open GPRS bearer
AT+WIPBR=1,6
  1. Set APN (replace “internet” with your APN)
AT+WIPBR=2,6,11,"internet"
  1. Start GPRS bearer
AT+WIPBR=4,6,0
  1. Connect TCP socket to remote server on port 80 in HTTP mode (substitute your URL, but you can use httpbin.org for testing)
AT+WIPCREATE=5,1,"httpbin.org",80
+WIPREADY 5, 1
  1. Do HTTP POST (adjust the content type, content length and other header data to suit your needs)
AT+WIPFILE=5,1,4,"http://httpbin.org/post","","","Accept","*/*","Accept-Encoding","deflate","Content-Type","application/json","Content-Length","9"
CONNECT
(NB: Now the modem is in data mode and does not echo bytes sent over UART)
It works![ETX]
(NB: [ETX] is the Unicode U+0003 character)
   "url": "http://httpbin.org/post",
                                      "json": null,
                                                     "data": "It works!",
        "form": {},
        "origin": "10.xxx.xx.xxx",
             "headers": {
                             "Content-Type": "application/json",
        "Accept": "*/*",
        "Accept-Encoding": "deflate",
                  "Connection": "close",
                                            "Content-Length": "9",
        "Host": "httpbin.org",
        "Transfer-Encoding": "chunked"
                             "files": {},
                                           "args": {}
+WIPFILE: 5,1,4,200,"OK"
  1. Close TCP socket
AT+WIPCLOSE=5,1
