Good Day,
I use the following code to check the input status every 1 second:
#include "adl_global.h"
/* Mandatory variables */
/* wm_apmCustomStack */
/* wm_apmCustomStackSize */
u32 wm_apmCustomStack [ 256 ];
const u16 wm_apmCustomStackSize = sizeof ( wm_apmCustomStack );
s8 gpio_subscribe_handle; //GPIO hanlde
/* Function : HelloWorld_TimerHandler */
/* Object : Timer handler */
/* Variable Name |IN |OUT|GLB| Utilisation */
/* ID | | | | Timer ID */
void HelloWorld_TimerHandler ( u8 ID )
/* Hello World */
//TRACE (( 1, "Embedded : Hello World" ));
//adl_atSendResponse ( ADL_AT_UNS, "\r\nHello World from Open-AT\r\n" );
TRACE (( 1, "I/O read:%d" ,adl_ioRead(gpio_subscribe_handle)));
/* Function : adl_main */
/* Object : Customer application initialisation */
/* InitType | | | | Application start mode reason */
TRACE (( 1, "Embedded : Appli Init" ));
/* Set 1s cyclic timer */
adl_tmrSubscribe ( TRUE, 10, ADL_TMR_TYPE_100MS, HelloWorld_TimerHandler );
gpio_subscribe_handle=adl_ioSubscribe(ADL_IO_Q24X6_GPI|ADL_IO_Q24X6_GPO_2,1,0,0,(adl_ioHdlr_f)NULL);
The code runs succesfully. As i have observed the initial return value on the adl_ioRead() function is “1”. when i tap the input to 2.7v source the value changes from “1” to “0” but no reaction when i tap it to ground. I seems that it is a positive triggered input. But what i would like to accomplish is the reverse of it so that when i tap the input to ground the value should toggle from “1” to “0” or “0” to “1”. Is their a way to accomplish this? Thank you in advance.
