Hi all,
First of all, I must say that I am newbie on Open AT and embedded modules. Please accept my apologies if I ask stupid questions.
I am using Q2687H embedded modules and developing an application to connect remote server, sending/receiving data with HTTP Client. I have some troubles with handling HTTP POST Response. I’ve used the sample codes provided by Developer Studio. It worked but when I send an HTTP POST request to server, I only can see the results on my TMConsole like following;
TMConsole logs:
HTTP Client Service test application : Init
GPRS: CONNECTED IP=92.64.193.57 DNS1=212.65.140.135 DNS2=212.65.156.200
http_ClientDataHandler: Start
http_ClientDataHandler: WIP_CEV_WRITE
http_ClientDataHandler: 73 bytes written
{"access_token":"3EMs2OvAhA6e9wzw1SPMpMArvQ08uQQM1-O3NLVsmmT7VLqeOvMzW1XBeQMxxUP8IiKN_whh63D-OFT5gifeRIyqB22Dr2wbJnQTvoDw2kWq1PMiRF1K1rw7IqiPya1DltFKvSwyqHMNojfa2f25Ju5daUOBNnhNA1xGC0RN4_W6P5-BHfxwXSGvsQoJzZLMhx3GAKop24K29_h1M7qi6icTuctKEFqGWI0EGmsFf_3wFzcpO2yCithHHmDCQKPAHp7Gf4J1K0gEVbzXMXkqaO087Tw5_FYZBCnaHs7d6TZttOCaQiNMuSMCUdLluv7-b_AvoFLmQtQuK_iocmOqGGiiM82ieWg9UREp-zUO7l22sPm68Cm6u3R6KmWdeQ3WCy5H6hQsbiOYo8yBMEGsSkp5BUtcXV20MNkrwa5_Wka_SRc_McmqK5eA67K4vuadSnFQ17qbzAHAjXoJt1YNtg","token_type":"bearer","expires_in":7199,"refresh_token":"cONjjU_LHm3AZVVxf048LaIdQ8dhu-0Ytny5dkrrA3M2M_ivBGypm4Cxi1RZQerUJSu5Bq6HV-Ay_iwu0dUDfFq4BOVaDgdL7J_kFme1mARJAB3flm77F25W2bn8UtFvOem31HhSWDCwyp_E5V652MNQRBdvZlrOouhYAIdo5CIIHLuxPepcfmKc9nFEl7EatRA56obaLTMEW6UuTGJjpcLxOkzB6M9QLGAWUghn_LZ3A4OB1Wqi-1HwWAvZS-dxv37gwawh_YjPJJHBA6xUqakLZ2uAN3zIK4ZWVOT0ZJA6sbP6H7UFQSvcBeDH3CfNBk8u01sh_xOHOM_yy9ElO2ZbvyyhXhhXji4F4OTHrXblMXLc75KXZmZXo_aZn5y0eI7ji7BztsyvHIDCmv3Kr3E9U_dm8CCik1mbXPkrPDSgruS9aC97t6DfBMjKzUzUf2nfJ5wv2xImSQR_KVlH-Q"}
http_ClientDataHandler: Done
http_ClientDataHandler: Status=200
http_ClientDataHandler: Reason="OK"
I need to handle the "{“access_token”:"3EMs2OvAhA6e9wzw1SPM… " part of the response data but I could not find the way how to handle it in WIP_CEV_READ or WIP_CEV_WRITE in event handler
Edit: Here is my handler code;
ascii *postData = "grant_type=password&UserName=usrName&Password=asdfghjkl#$123&CityCode=46";
static void http_ClientDataHandler ( wip_event_t *ev, void *ctx )
ascii Ptr_OnTrace [ 240 ];
int len, tmplen;
s32 status;
http_ClientCtx_t *pHttpClientCtx = ( http_ClientCtx_t * ) &http_ClientCtx;
switch ( ev->kind )
case WIP_CEV_OPEN:
TRACE ( ( NORMAL_TRACE_LEVEL, "http_ClientDataHandler: WIP_CEV_OPEN" ) );
adl_atSendResponse ( ADL_AT_UNS, "http_ClientDataHandler: Start\r\n" );
/* ready for getting response data */
pHttpClientCtx->dataLength = 0;
break;
case WIP_CEV_READ:
TRACE ( ( NORMAL_TRACE_LEVEL, "http_ClientDataHandler: WIP_CEV_READ" ) );
/* we must read all available data to trigger WIP_CEV_READ again */
tmplen = 0;
while ( ( len = wip_read ( ev->channel, tmpbuf, sizeof ( tmpbuf ) - 1 ) ) > 0 )
tmpbuf [ len ] = 0;
adl_atSendResponse ( ADL_AT_UNS, tmpbuf );
tmplen += len;
TRACE(( NORMAL_TRACE_LEVEL, "http_ClientDataHandler: read %d bytes", tmplen ));
/* compute total length of response */
pHttpClientCtx->dataLength += tmplen;
break;
case WIP_CEV_WRITE:
TRACE(( NORMAL_TRACE_LEVEL, "http_ClientDataHandler: WIP_CEV_WRITE\n" ));
adl_atSendResponse ( ADL_AT_UNS, "\r\nhttp_ClientDataHandler: WIP_CEV_WRITE\r\n");
sentBytes = wip_write( pHttpClientCtx->DataChannel, postData, wm_strlen(postData));
if(sentBytes < 0)
{/* error */
adl_atSendResponse ( ADL_AT_UNS, "\r\nwip_write error\r\n" );
return;
else
TRACE(( 4, "http_ClientDataHandler: bytes %d written\n", sentBytes ));
wm_sprintf( tmpbuf, "\r\nhttp_ClientDataHandler: %d bytes written\r\n", sentBytes);
adl_atSendResponse ( ADL_AT_UNS, tmpbuf);
wip_shutdown( pHttpClientCtx->DataChannel, FALSE, TRUE);
break;
case WIP_CEV_PEER_CLOSE:
TRACE ( ( NORMAL_TRACE_LEVEL, "http_ClientDataHandler: WIP_CEV_PEER_CLOSE" ) );
adl_atSendResponse ( ADL_AT_UNS, "\r\nhttp_ClientDataHandler: Done\r\n" );
/* end of data */
/* show response information */
if ( wip_getOpts ( ev->channel,
WIP_COPT_HTTP_STATUS_CODE, &status,
WIP_COPT_HTTP_STATUS_REASON, tmpbuf, sizeof ( tmpbuf ),
WIP_COPT_END ) == OK )
ascii sbuf [ 16 ];
adl_atSendResponse ( ADL_AT_UNS, "http_ClientDataHandler: Status=" );
wm_sprintf ( sbuf, "%d", ( s16 ) status );
adl_atSendResponse ( ADL_AT_UNS, sbuf );
adl_atSendResponse ( ADL_AT_UNS, "\r\nhttp_ClientDataHandler: Reason=\"" );
adl_atSendResponse ( ADL_AT_UNS, "\"\r\n" );
TRACE ( ( NORMAL_TRACE_LEVEL, "http_ClientDataHandler: Status=%d", status ) );
wm_sprintf ( Ptr_OnTrace, "http_ClientDataHandler: Reason=\"%s\"", tmpbuf );
TRACE ( ( NORMAL_TRACE_LEVEL, Ptr_OnTrace ) );
WIP_COPT_HTTP_HEADER, "content-type", tmpbuf, sizeof ( tmpbuf ),
wm_sprintf ( Ptr_OnTrace, "http_ClientDataHandler: Content Type=\"%s\"\n", tmpbuf );
TRACE ( ( NORMAL_TRACE_LEVEL, "http_ClientDataHandler: Response Length=%d bytes", pHttpClientCtx->dataLength ) );
/* data channel must be closed*/
wip_close( ev->channel );
break;
case WIP_CEV_ERROR:
TRACE ( ( ERROR_TRACE_LEVEL, "http_ClientDataHandler: WIP_CEV_ERROR %d", ev->content.error.errnum ) );
adl_atSendResponse ( ADL_AT_UNS, "http_ClientDataHandler: ERROR\r\n" );
/* connection to server broken */
wip_close( ev->channel);
break;
default:
TRACE ( ( ERROR_TRACE_LEVEL, "http_ClientDataHandler: unexpected event: %d", ev->kind ) );
break;
Can you tell me if you have any idea?
Thanks in advance.
Best regards
MÇ.
