zuuuuk
March 15, 2024, 12:02pm
1
Hello.
I am using the Wp7502 chip.
A LAN9030i chip from the microchip company is connected to it.
The Wp7502 and LAN9030i chips are connected via the HSIC interface.
The LAN9030i chip acts as an HSIC to ehternet interface converter.
i read that SMSC driver support LAN9030i
And i find
root@swi-mdm9x15:/dev# dmesg | grep smsc95xx
[ 2.355318] usbcore: registered new interface driver smsc95xx
[ 2.914726] smsc95xx v1.0.4
[ 3.021913] smsc95xx 1-1:1.0 eth0: register 'smsc95xx' at usb-msm_hsic_host-1, smsc95xx USB 2.0 Ethernet, c2:90:9d:1d:81:e9
[ 13.790935] smsc95xx 1-1:1.0 eth0: link up, 100Mbps, full-duplex, lpa 0xC5E1
I see that smsc95xx version 1.0.4
I found a newer version of the driver.
How can I update my driver to a higher version?
Where can I download this driver?
jyijyi
March 15, 2024, 2:13pm
2
Do you see such driver in the yocto source ?
zuuuuk
March 15, 2024, 2:42pm
3
I use source
https://downloads.sierrawireless.com/AirPrime/WPx5xx/Release17/Legato-Dist-Source-mdm9x15-SWI9X15Y_07.14.01.00.tar.bz2
But there is an old version of smsc95xx.
#define SMSC_DRIVER_VERSION "1.0.4"
So I have a question. Is it possible to somehow update the system or this driver specifically?
jyijyi
March 15, 2024, 3:11pm
4
can you copy and paste the new driver to the same location and recompile the yocto image?
I check this link. It is helpful for me. Thanks
zuuuuk
March 20, 2024, 9:51am
6
I came to the conclusion that in order for me to update the driver in this assembly I need to do the following.
Download Linux sources for this Wp 7502
Rebuild them by disabling the old driver
Build a new driver as a separate module
Load this new driver (module) after the system starts.
Tell. Is this the correct algorithm of action?
Or am I missing something?
jyijyi
March 20, 2024, 9:55am
7
yes, it could be if it works for your hardware
Or you can update the drive source inside yocto source to rebuild the image
zuuuuk
March 21, 2024, 7:23am
8
Thanks for the answer. I have a follow-up question. Is it possible to switch to Linux 4.14?
I assume the drivers there are more recent
I currently have Linux 3.
jyijyi
March 21, 2024, 7:28am
9
this linux 4.14 is for WP76/WP77, not for your WP75xx module
