Hi @ all,
I’m still stuggling with some tcp socket issues
I’m opening a socket connection to a server, sending some data. Works fine. But, how to close this socket from the module’s (=client) side? Haven’t found any info about that in the doc.
Just to mention, I’m running a Q2501 with OAT 3.10 and eDLib.
Tia, Heinz
Hello Heinz,
I’m pretty sure that you close the socket by sending nothing from the client, so
err = ed_SendDataExt( "", 0, TRUE, ED_ID_TCPSOCKET_1 );
should do it.
Best Regards, Jan
Hi Jan, thanks for the hint. But maybe with a NULL instead of “”… Anyway, I’ll give it a try.
Thanks, Heinz
NULL and empty string are different. For that case I always used “”/empty string myself.
NULL isn’t “”, sure.
IMO the trick is sending a len=0.
I’ve given it a try, works also with NULL,0.
Heinz
